I have a HP MINI 210-1010NR and just installed Ubuntu 11.04 and I can't get my wireless to work. I have checked through multiple Q&A's throughout this FAQ and tried them all. When I go over the wireless thing at the top it says "Wireless Networks device not ready (firmware missing)."
Okay, now here is my
lspci -vvnn | grep 14e4
02:00.0 Network controller [0280]: Broadcom Corporation BCM4312 802.11b/g
LP-PHY [14e4:4315] (rev 01)
Also, when I try to open additional drivers it says that "Downloading package indexes failed, please check your network status." I have no means of other Internet Access.
I tried to do the ndisgtk things and attempted to install all of the things that were in the photo but I don't know where to find them.
Eric Carvalho
  • 55,453
ptran221
  • 31
8 Answers8
You need to have internet for jockey to install wireless driver so make sure you have wired internet first.
If You want to go manual route try:
sudo apt-get install bcmwl-kernel-source
And see if your wireless works or not else try:
sudo apt-get purge bcmwl-kernel-source && sudo apt-get install firmware-b43-installer
If the first process doesnot work.
sagarchalise
  • 24,306
I have the same problem with same driver. This is what I do to install the correct drivers.
1st, install Synaptic Package Manager from the USC, Ubuntu Software Center. It has always been default in Ubuntu until 11.10, but it still works great. Open Synaptic and search for B43. This is what you will get.
Synaptic - B43
Notice the choices available and the drivers I downloaded. If you have a question you can click on the item and a brief description will pop up. It works on my dv5000 series, I just did a fresh install last night. Good Luck!
lqlarry
  • 746
git clone git://git.kernel.org/pub/scm/linux/kernel/git/dwmw2/linux-firmware.git
cd linux-firmware
sudo cp -a brcm /lib/firmware
sudo modprobe -r brcm80211 && sudo modprobe brcm80211
profit (:
N.N.
  • 18,589
Roma
This solution encompasses many of the other suggestions you have received so far.
Try connecting to a wired connection (preferably do this somewhere with a wired connection (for the downloads) and a wireless network (to test the drivers)), and following the instructions in this wiki of the Ubuntu Community Documentation. Thus old, this document is still usable.
I have that same network card and both the STA and the B43 drivers work for me. Good luck!
Severo Raz
  • 6,111
Atom Netbook 110 ~ Windows7:Wubi: Ubuntu 12.04
Wireless trouble out-of-the-box
After several Trouble shootings,
Solution:
USC: Synaptic Package installer
-Opened Package Installer>search "b43" -Installed 3 packages: firmware-b43-lpphy-installer b43-fwcutter firmware-b43legacy-installer
Restart.
worked
LlidD
In fact the firmware-b43-lpphy-installer and/or b43-fwcutter is all you need.
firmware-b43-installer and firmware-b43legacy-installer do not even install properly on 4312 hardware.
The STA driver (aka bcmwl) may work but not always, so I recommend firmware-b43-lpphy-installer.
Eric Carvalho
  • 55,453
Try ndiswrapper (you most likely have to install it, so sudo apt-get install ndisgtk). This program allows you to use windows drivers for wifi under linux so you have to just download appropriate driver from here and use it with ndiswrapper (it has a gui which you can start by ndisgtk in terminal). The interface is quite simple, there should be no problems with that.
foxy
  • 623
There's no need for ndiswrapper and Windows drivers, because the Linux driver already exists,
  • if you see no broadcom wireless device name, uninstall driver, restart computer, install driver and restart again until "firmware missing" message appears with wifi device name under wireless icon after clicking on it (gnome).
  • If you haven't it, you must install a synaptic package manager from Ubuntu software center
  • search "bcm" inside synaptic package manager
  • mark for installation "b43-fwcutter", "firmware-b43-installer", "firmware-b43legacy-installer" and apply, no restart needed. Your Wi-Fi led turns on immediately.
