Unable login to my account from GUI interface, only as Guest. When trying to login, within a few seconds I'm sent back to the login screen. Further, after trying some fixes, when trying login as admin, login screen is not returning back, get only a blank screen and it does not proceed further. Can only Guest login. Login from tty4 terminal is OK.
.xsession-errors contains only these lines:
Can't save user-dirs.dirs
Script for ibus started at run_im.
Script for auto started at run_im.
Script for default started at run_im.
init:/home/username/.config/upstart: Unable to load configuration: Permission denied
init: dbus pre-start process (4902) terminated with status 1
Zanna
  • 72,312
minto
  • 831
I just had the same issue and found that the solution @minto posted as a comment worked for me, along with changing the .Xauthority and .ICEauthority permissions.
To summarize:
sudo chown -R username:username /home/username
Then logout and reboot.
If that didn't work then check out SiddharthaRT's answer on changing .Xauthority and .ICEauthority permissions in answer to Ubuntu gets stuck in a login loop.
Zanna
  • 72,312
Weevils
  • 111
