I am using 14.04.4 and after when I update my software via software updater I cannot see my wifi connections after a reboot. I used dual-boot with windows and secure boot is turned on. Secure boot was enabled at the first place and I don't want to turn it off. How can I address this problem? I am using Broadcom BCM43142 adapter.
ashwani
  • 121
The actual reason is during the upgrade it removes some packages in ubuntu. One of the package might be the WiFi driver of the system. So, what I did in this situation is I visited the Ubuntu community documentation page which details all about WiFi drivers.
Follow the documentation guide if this did not work
This instruction is for Broadcom only
To identify the wifi driver type the following command
  • If it's an Internal card
    lspci -vvnn | grep -A 9 Networ
  • If it's an USB card
    usb-devices
Now you have to download the driver from the documentation page and extract  the folder inside the package to the desktop. Then open the folder. In the folder right click on the window showing the WiFi driver content and click "Open in terminal". Then you have to type the following command below in order.
sudo apt-get update
sudo apt-get --reinstall install bcmwl-kernel-source
Now you're done. Check if the WiFi works.
mxdsp
  • 3,988
I used "BLOG SLONIA" from POLAND For ubuntu 12.04-14.04 thanks
Run the terminal and type:
Sudo passwd
We give the root password, then:
Su
Command prompt:
Apt-get update
Apt-get remove bcmwl-kernel-source
The problem is confirmed by Y enter. After unpacking the package and removing the dkms module, we include:
Apt-get install the firmware-b43-installer
Apt-get install b43-fwcutter
Modprobe b43
Ifconfig wlan0 up
And finally we restart the system with the command:
Restart
After restarting our computers is what we need
