I am attempting to install handbrake by using the below commands:
sudo add-apt-repository ppa:stebbins/handbrake-releases
sudo apt-get update
sudo apt-get install handbrake-gtk
Which throws an error of:
Reading package lists... Done Building dependency tree
Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: handbrake-gtk : Depends: libmp3lame0 (>= 1:3.99.0) but 3.99.5+repack1-7+deb8u1 is to be installed Recommends: gstreamer1.0-x but it is not going to be installed E: Unable to correct problems, you have held broken packages.
So I ran thebelow to see what was held broken packages:
sudo apt-mark showhold
Which returned nothing. So I then decided to check on both gstreamer and libmp3lame0 and ran
sudo apt-get install libmp3lame0
sudo apt-get install gstreamer0.10-ffmpeg
Which presented a message of * program is already installed. Then again I tried
sudo apt-get update --fix-missing
And the errors I got were:
Lastly, I tried using sudo apt-get install -f handbrake-gtk which threw the same error as installing with no -f parameter.
With all that being said, what do I need to do in order to install handbrake?
And my system details are:
DistributerID: BunsenLabs
Description: BunsenLabs GNU/Linux 8.5 (Hydrogen)
Release: 8.5
Codename: Bunsen-Hydrogen
EDIT
I am looking for a video convertor (i.e. re-encoder to resize and change the container on some cell phone videos)
Bunsen Labs is based directly on Debian, so you shouldn't be able to install Handbrake from its official repository.
You can install it instead from Bunsen's repositories. It won't be the latest version but it should work on your machine.
First you have to remove the added repo with
sudo add-apt-repository --remove ppa:stebbins/handbrake-releases
and then do the following:
sudo apt-get update
belacqua
  • 23,540
