currently I'm using Ubuntu 16.04 and have set my User UID to 501 (interop with Mac).
However even after setting login.defs:
UID_MIN                   500
UID_MAX                 60000
# System accounts
#SYS_UID_MIN              100
SYS_UID_MAX               499
It wil still not work and neither display the user in lightdm nor in the Ubuntu User Settings, any ideas?
Not only the user but also the group can bet set, look into the following
 GID_MIN                  1000
 GID_MAX                 60000
# System accounts
SYS_GID_MIN               100
SYS_GID_MAX               499
s1mmel
  • 2,124
so once you have reset your userid and got lightdm back again.
the problem looks like you are using nfs3 instead of nfs4 , nfs4 should work happily with usernames instead of userids. This way you just need the names to match.
check that the exporting server is running nfs4 and exporting in nfs4 mode.
ubuntu should be nfs4 on the client end but may need to be told not to use 'sys' authentication (which is looking up UID's not names).
Amias
  • 5,359
Just tried changing /etc/login.defs:
# Min/max values for automatic uid selection in useradd
UID_MIN                   100
UID_MAX                 60000
# System accounts
#SYS_UID_MIN              100
#SYS_UID_MAX              999
# Min/max values for automatic gid selection in groupadd
GID_MIN                   100
GID_MAX                 60000
# System accounts
#SYS_GID_MIN              100
#SYS_GID_MAX              999
After reboot, lightdm shows all users with uid > 100 && gid > 100, and they are shown in Ubuntu User Manager (I have no users with UID between 500 and 1000, so tried 100). I think S1mmel is right here.
Are you sure accountsservice is running?
ridgy
  • 2,516
