I have followed the instructions from this answer to similar question, but it looks like the installer in sudo mode installs most of plugins to /root/.p2/pool/plugins, so you can't access it in non-sudo mode.
I have copied .p2 folder (/root/.p2) to my install folder (/opt/eclipse/) and changed launcher library path in eclipse.ini file to point to the new location.
Unfortunately, that did not help:
An error has occurred.  See the log file
/home/michal-praca/.eclipse/org.eclipse.platform_4.6.0_1942444138_linux_gtk_x86_64/configuration/1469604630174.log
!SESSION Wed Jul 27 09:25:23 CEST 2016 ----------------------------------------- !ENTRY org.eclipse.equinox.launcher 4 0 2016-07-27 09:25:23.561 !MESSAGE Could not find extension: reference:file:org.eclipse.osgi.compatibility.state_1.0.200.v20160504-1419.jar !ENTRY org.eclipse.equinox.launcher 4 0 2016-07-27 09:25:23.565 !MESSAGE Could not find extension: reference:file:org.eclipse.wst.jsdt.nashorn.extension_1.0.0.v201605131737.jar !ENTRY org.eclipse.equinox.launcher 4 0 2016-07-27 09:25:23.570 !MESSAGE Exception launching the Eclipse Platform: !STACK java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter at java.net.URLClassLoader.findClass(URLClassLoader.java:381) at java.lang.ClassLoader.loadClass(ClassLoader.java:424) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:670) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
How to install Eclipse Neon using installer in such a way, that any user on the system can use it?
I'm using Ubuntu 14.04.
dlin
  • 3,900
