I just installed Ubuntu 12.04.5 in my old Fujitsu Siemens Esprimo Mobile v5535, but i think the graphics card driver is not installed with, because whenever i open a window, I can't see the whole thing. For example, when I google something, I can't see the research results properly, as everything is just huge. I tried to change the resolution but the only option is 640x480. Can somenone help me fixing this?
You can install a driver, but you will need to downgrade the graphical stack to support the driver.
Run in terminal
sudo apt-get install xserver-xorg xserver-xorg-input-all
You will be asked to agree to remove lots of packages and install lots too. You will need to agree with that.
Reboot.
If the procedure was OK, then proceed. You will need to install some packages and build the driver.
Run in terminal (one-by-one).
sudo apt-get install git xorg-dev mesa-common-dev libdrm-dev libtool build-essential
sudo apt-get install x11proto-xf86dga-dev x11proto-xf86dri-dev x11proto-gl-dev libxext-dev
git clone git://github.com/hellnest/xf86-video-sismedia-0.9.1.git
cd xf86-video-sismedia-0.9.1
./configure --prefix=/usr --disable-static
sudo make install
Reboot again. You will be able to set 1280x800 resolution.
There may be issues with running videos. If you meet any, let me know. I will try to remember how they are fixed.
Don't be worried with funny things happening with the splash screen with Ubuntu logo at boot and shutdown. It is OK.
Do not upgrade the system to 14.04. There is no way to get the graphics adapter work properly on new Ubuntu versions.
You may also meet a problem with video playback. In this case run
gstreamer-properties
and switch output to X11.
If you are using VLC, you will need to switch output in VLC settings.
- 92,041
this solved me: sudo nano /etc/default/grub ;uncomment the line; #GRUB_GFXMODE=640x480 to p.ex. GRUB_GFXMODE=1024x768 ;save and; sudo update-grub ;on next boot you'll have the desired screen resolution
- 1
