After the recent update I wasn't able to start my system (black screen). So I powered off the PC and turned it on again.
Saw the following grub menu:
Ubuntu
Advanced options for Ubuntu
System setup
I selected "Advanced options for Ubuntu" and saw:
Ubuntu, with Linux 4.2.0-42-generic
Ubuntu, with Linux 4.2.0-42 ... (recovery mode) ...
Ubuntu, with Linux 4.2.0-41-generic
Ubuntu, with Linux 4.2.0-41 ... (recovery mode) ...
I selected Ubuntu, with Linux 4.2.0-41-generic and the system started (previously with Ubuntu, with Linux 4.2.0-42-generic selected it didn't)
As I didn't always want to select it manually I tried to set it as the default kernel in grub: So I opened '/etc/default/grub' and changed:
GRUB_DEFAULT=2
Then executed $sudo update-grub and restarted the system. But it still wanted to load the latest kernel.
I also tried it with GRUB_DEFAULT=3 but the result was the same.
My grub is:
#grub-install --version
grub-install (GRUB) 2.02~beta2-9ubuntu1.11
I also got some errors while installing grub customizer:
dpkg: dependency problems prevent configuration of linux-signed-generic-lts-wily:
linux-signed-generic-lts-wily depends on linux-signed-image-generic-lts-wily (= 4.2.0.42.34); however:
Package linux-signed-image-generic-lts-wily is not configured yet.
dpkg: error processing package linux-signed-generic-lts-wily (--configure):
dependency problems - leaving unconfigured
Setting up grub-customizer (5.0.6-0ubuntu1~ppa1t) ...
linux-image-4.2.0-42-generic
linux-image-extra-4.2.0-42-generic
linux-image-generic-lts-wily
linux-generic-lts-wily
linux-signed-image-4.2.0-42-generic
So I'm not sure whether I should reboot or uninstall it...
