I want to get rid of the Hibernate and Suspend options on the top-right menu in Unity. These do not work on my netbook and having them close to "logout" is not useful.
Jorge Castro
  • 73,717
lourencoj
  • 170
I assume you're using a much earlier distro since this post is apparently from 5 months ago. Anyway, I just did the opposite of what you're doing yesterday on Precise. Run the following command to open the file to edit:
sudo gedit /var/lib/polkit-1/localauthority/10-vendor.d/com.ubuntu.desktop.pkla
Scroll to the bottom. Check to see if the following information exists, and if not add them:
[Disable hibernate]
Identity=unix-user:*
Action=org.freedesktop.upower.hibernate
ResultActive=no
[Disable suspend]
Action=org.freedesktop.upower.suspend
ResultActive=no
Doing this makes those options do nothing when you click them; they will disappear from the menu after you restart your computer.
Jakob
  • 10,789
