Condition: to activate zswap module in Ubuntu 16.04 successfully for Matlab/.... computation
Relevant part in /etc/default/grub
zswap.enabled=1 # NB only change here
GRUB_CMDLINE_LINUX=""
# NB also tried to have the line here unsuccessfully
I try to activate zswap and run sudo update-grub
Searching for GRUB installation directory ... found: /boot/grub
/etc/default/grub: line 12: zswap.enabled=1: command not found
I also tried the code where zswap line is after GRUB_CMDLINE_LINUX="" unsuccessfully.
My current setting after heynnema's answer
Have the following in
/etc/default/grub, which works unspecifically;dmesg | grep zswapsreturns something# https://wiki.archlinux.org/index.php/Zswap GRUB_CMDLINE_LINUX_DEFAULT="quiet splash zswap.enabled=1 zswap.max_pool_percent=25 zswap.compressor=lzo"Run
sudo update-grub.
Its effect on the maximum Ram?
There are some threads about it is saving some pages in the pool, etc zswap: How to determine whether it is compressing swap pages? However, there is no studies about its effect on the maximum Ram for the computaion.
System: Linux Ubuntu 16.04 64 bit
Linux kernel: 4.6
Linux kernel options: wl
Matlab: 2016a
Hardware: Macbook Air 2013-mid
Related threads: How can I enable zswap?, Zswap Arch Linux, zswap: How to determine whether it is compressing swap pages?
