I've installed Linux alongside Windows. I have two operating systems (windows and ubuntu).I was assigned one of the drives of Windows to Linux. If I want to change my windows,Do I also need to re-install Linux?
Asked
Active
Viewed 73 times
I'm confused by your question. If you've lost your Ubuntu install after installing Windows... as per help.ubuntu.com.
- Insert your Ubuntu CD, reboot your computer and set it to boot from CD in the BIOS and boot into a live session. You can also use a LiveUSB if you have created one in the past.
- Install and run Boot-Repair
- Click "Recommended Repair".
- Now reboot your system. The usual GRUB boot menu should appear. If it does not, hold Left Shift while booting. You will be able to choose between Ubuntu and Windows.
kneeki
- 317
