I believe I downloaded UBUNTU OS correctly, and tried to load it onto a usb stick, but I am unable to boot-up from the stick. any help would be much appreciated
If you have windows installed on your machine, i would recommend you using Rufus. its a very famous tool to create bootable USB drive Download it from the page: https://rufus.akeo.ie/. this tool is the answer to create bootable media for any kind of OS. if you face any issue using the tool, comment back.
You can use an in-built software from ubuntu to put that on USB Stick. Go to System Tools -> Administration -> Startup Disk Creator. Select the USB device and the Ubuntu image. Would take about 2minutes and then you are done.
Sanchit
  • 129
