As the question tells how should I install jsonccpp in ubuntu 14.04. I have downloaded the jsoncpp-src-0.5.0.tar.gz form sourceforge. Then I opened nautilus using sudo and copied,pasted and extracted the tar.gz file in /opt. I have installed the cmake and used this code to install as suggested in the jsoncpp github
cmake -DCMAKE_BUILD_TYPE=debug -DBUILD_STATIC_LIBS=ON -DBUILD_SHARED_LIBS=OFF \
      -DARCHIVE_INSTALL_DIR=. -G "Unix Makefiles"
But its giving this error
CMake Error: The source directory "/opt/jsoncpp-src-0.5.0" does not
appear to contain CMakeLists.txt. Specify --help for usage, or press
the help button on the CMake GUI.
  • Codeblocks is used as C++ development IDE
Eka
  • 3,007
Your installation with cmake fails because you are downloading a very old version of jsoncpp from SourceForge , a version that actually does not use cmake. The file README.txt with the 0.5.0 tarball has the details:
* Building/Testing:
JsonCpp uses Scons (http://www.scons.org) as a build system. Scons
requires python to be installed (http://www.python.org).
Newer versions of jsoncpp are seen on GitHub (latest stable version is 1.7.3) and these actually do use cmake to build.
However a reasonable version exists in the Trusty Repositories and the following command will get you jsoncpp 0.6.0:
sudo apt-get install libjsoncpp-dev libjsoncpp0
Here are the details of the package on my system:
andrew@corinth:~$ apt-cache policy libjsoncpp-dev
libjsoncpp-dev:
  Installed: 0.6.0~rc2-3ubuntu1
  Candidate: 0.6.0~rc2-3ubuntu1
  Version table:
 *** 0.6.0~rc2-3ubuntu1 0
        500 http://au.archive.ubuntu.com/ubuntu/ trusty/universe amd64 Packages
        100 /var/lib/dpkg/status
andrew@corinth:~$
If you need a newer version this can be built from source but perhaps this version is enough for your purposes...
andrew.46
  • 39,359
