I have recently installed Ubuntu on additional partitions on my secondary hard disk. The installation seems to have worked, but I can't find a way to actually boot to Ubuntu. Arranging the boot order didn't work, it seems the secondary drive is completely, with all its partitions being ignored. Did I do something wrong or is it just not working with this kind of system?
EDIT: BootInfo: http://paste2.org/wwXXJ1ZY
Often Boot-Repair can fix booting type issues with Ubuntu and some other Linux. It can only do very minor fixes to Windows issues. One fix often is just a install of grub to MBR if BIOS or to ESP if UEFI. But some need advanced options and full reinstall of grub.
https://help.ubuntu.com/community/Boot-Repair
Occasionally with complex configurations, it is better to have someone who understands issues review details. You can post the Summary Report from Boot-Repair.
https://help.ubuntu.com/community/Boot-Info
Boot-Repair will not create partitions, with gpt partitioning you may need either the ESP - efi system partition(UEFI boot) or a bios_grub partition(BIOS boot). If older BIOS/MBR, it does not require additional partitions.
How to prepare a disk on an EFI based PC for Ubuntu?
Boot-Repair can create a copy of shimx64.efi as /EFI/Boot/bootx64.efi if you tick/check the 'Use the standard EFI file' in advanced options. Boot-Repair also suggests one of several alternative methods (BCD edit) to get UEFI systems that only want to boot Windows. Other methods:
Dual boot Win 8 / Ubuntu loads only Win
oldfred
  • 12,583
