Ubuntu loads from the live CD but after going through the install it requires me to put the live boot in I did a complete erase and install with Ubuntu 16 is there anyway I can use terminal to format the hard drive and start again I do know it probably has some corrupt areas, I even tried loaded from CD of Windows XP but the drive wont read it but at least I get a working desktop with the Ubuntu 6 version Can any guru's out there give me the script to type in exactly and see if I can get this PC up and running again if not it's probably trashed completely thanks in advance
Asked
Active
Viewed 71 times
If you can boot live Ubuntu, then you should use GParted , a free partition editor.
First, unmount your hard disk (right click -> Unmount). Then you will see Format to and choose ntfs file system. Apply the changes and that´s it.
Also, there is answer about formatting from terminal. Hope it will be helpful to you.
Don´t forget to make backup!
