When i login i see
8 packages can be updated.
7 updates are security updates.
When i try
apt-get update
Hit:1 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease
Get:4 http://security.ubuntu.com/ubuntu xenial-security InRelease [94.5 kB]
Fetched 94.5 kB in 0s (161 kB/s)
Reading package lists... Done
When i try
apt-get upgrade
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
linux-image-extra-4.4.0-31-generic : Depends: linux-image-4.4.0-31-generic but it is not installed
linux-image-generic : Depends: linux-image-4.4.0-31-generic but it is not installed
Recommends: thermald but it is not installed
E: Unmet dependencies. Try using -f.
If i try apt-get -f install as suggested above that also fails
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
linux-headers-4.4.0-21 linux-headers-4.4.0-21-generic linux-headers-4.4.0-22
linux-headers-4.4.0-22-generic linux-image-4.2.0-34-generic linux-image-4.4.0-21-generic
linux-image-4.4.0-22-generic linux-image-extra-4.2.0-34-generic linux-image-extra-4.4.0-21-generic
linux-image-extra-4.4.0-22-generic
Use 'apt autoremove' to remove them.
The following additional packages will be installed:
Suggested packages:
fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 14 not upgraded.
5 not fully installed or removed.
Need to get 0 B/18.7 MB of archives.
After this operation, 55.5 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 225185 files and directories currently installed.)
Preparing to unpack .../linux-image-4.4.0-31-generic_4.4.0-31.50_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-31-generic (4.4.0-31.50) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-31-generic_4.4.0-31.50_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.4.0-31-generic' to '/boot/vmlinuz-4.4.0-31-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-31-generic /boot/vmlinuz-4.4.0-31-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-31-generic /boot/vmlinuz-4.4.0-31-generic
Based on Comments
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda1 240972 229789 0 100% /boot
