I'm fairly new to Ubuntu, so I don't know if this is a simple fix or not. I've read some fixes to answers for my problem but I don't really know how to do any of the things they're telling me to do (such as installing proprietary drivers). I'm having the same problem that UbhiSukhpal posted about, but my attempts at fixing the problem have not been successful. Starting Steam from Terminal hasn't worked either. This is the message I get when I try to do start it from the terminal.
    chris@chris-VPCEE41FX:~$ steam
    Running Steam on ubuntu 15.04 64-bit
    STEAM_RUNTIME is enabled automatically
    Installing breakpad exception handler for appid(steam)/version(0)
    libGL error: unable to load driver: r600_dri.so
    libGL error: driver pointer missing
    libGL error: failed to load driver: r600
    libGL error: unable to load driver: swrast_dri.so
    libGL error: failed to load driver: swrast
Any help would be awesome. I apologize if this is going to be tedious. :p
marisusis
  • 360
I have the same problem on Arch Linux but not on Ubuntu. On Arch I solved it by using this script to launch Steam.
LD_PRELOAD='/usr/$LIB/libstdc++.so.6 /usr/$LIB/libgcc_s.so.1 /usr/$LIB/libxcb.so.1 /usr/$LIB/libgpg-error.so' steam
You can adapt and integrate that into /usr/share/applications/steam.desktop or make a new launch script, like /usr/bin/steam-start
You can also solve it by removing certain libraries from the steam-runtime folder. I used that before but the steam-runtime tends to get regenerated so I don't recommend this. I don't remember the exact files but here's a useful discussion.
On Arch this is caused by the system libraries being at the latest version, and thus incompatible with Steam. On Ubuntu this shouldn't be an issue since they are at a supported version, and Ubuntu is a supported distro by Valve.
andrew.46
  • 39,359
