I am using Virtual Machine Manager in Ubuntu 15.10. When I try to login after giving correct username and password the system is showing again the login screen. I can not use hot key because whenever I pressed hot key it always go to host machine not the guest or virtual machine.
  1. CTRL + Alt + F1 in the Login screen to access terminal
  2. apt-get remove --purge < full name of the package you just installed)
  3. whereis < full name of package >
  4. manually remove everything related to that package
  5. sudo reboot
Hellas
  • 69
