I was wondering about the following;
I use the following command to find .jpg files in (sub)directorys and convert (mogrify) them to .webp files.
find . -name '*.jpg' -execdir mogrify -format webp {} \;
In this case: file.jpg becomes file.webp (and .jpg is kept).
What I want is:
Example: file.jpg becomes file.jpg.webp (and .jpg is kept).
  1. How can I modify my code that it will set .jpg.webp?
  2. Is there a code that checks if a file is already converted so it will pass, UNLESS the original .jpg file is newer?
Thanks in advance!
andrew.46
  • 39,359
HRR
  • 41
Your first question can be addressed easily enough:
find . -iname '*.jpg' -exec  convert '{}' -format webp '{}'.webp \;
This will:
  1. Recursively find all .jpg files, as in your example
  2. Convert each .jpg file to webp using convert rather than mogrify
  3. Use the naming convention you were after: 'filename.jpg.webp'
Tested nicely on my system...
References:
andrew.46
  • 39,359
