I am trying to install Virtual Box in my Ubuntu 14.04 Box. I downloaded the package file from official website here
I tried installing this package but it is throwing errors. Below is the information reported in terminal-
ravi@Dell:~$ sudo dpkg -i Downloads/virtualbox-5.1_5.1.0-108711-Ubuntu-trusty_amd64.deb
[sudo] password for ravi:
Selecting previously unselected package virtualbox-5.1.
(Reading database ... 440671 files and directories currently installed.)
Preparing to unpack .../virtualbox-5.1_5.1.0-108711-Ubuntu-trusty_amd64.deb ...
Unpacking virtualbox-5.1 (5.1.0-108711~Ubuntu~trusty) ...
Setting up virtualbox-5.1 (5.1.0-108711~Ubuntu~trusty) ...
Adding group `vboxusers' (GID 125) ...
Done.
vboxdrv.sh: failed: modprobe vboxdrv failed. Please use 'dmesg' to find out why.
There were problems setting up VirtualBox.  To re-start the set-up process, run
  /sbin/vboxconfig
as root.
Processing triggers for ureadahead (0.100.0-16) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Below are the few lines from the bottom of dmesg command-
[   85.053851] wlan0: AP advertised VHT without HT, disabling both
[   85.060656] wlan0: send auth to 18:64:72:1d:51:50 (try 1/3)
[   85.061293] wlan0: authenticated
[   85.064889] wlan0: associate with 18:64:72:1d:51:50 (try 1/3)
[   85.065625] wlan0: RX AssocResp from 18:64:72:1d:51:50 (capab=0x11 status=0 aid=5)
[   85.067183] wlan0: associated
[   85.071714] cfg80211: Regulatory domain changed to country: JP
[   85.071723] cfg80211:  DFS Master region: unset
[   85.071725] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   85.071729] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   85.071731] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   85.071734] cfg80211:   (4910000 KHz - 4990000 KHz @ 40000 KHz), (N/A, 2300 mBm), (N/A)
[   85.071736] cfg80211:   (5030000 KHz - 5090000 KHz @ 40000 KHz), (N/A, 2300 mBm), (N/A)
[   85.071739] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   85.071742] cfg80211:   (5250000 KHz - 5330000 KHz @ 40000 KHz), (N/A, 2000 mBm), (0 s)
[   85.071744] cfg80211:   (5490000 KHz - 5710000 KHz @ 40000 KHz), (N/A, 2300 mBm), (0 s)
[   85.165436] wlan0: Limiting TX power to 23 (23 - 0) dBm as advertised by 18:64:72:1d:51:50
[  372.263572] capability: warning: `VirtualBox' uses 32-bit capabilities (legacy support in use)
[  702.263467] systemd-hostnamed[9090]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[  852.612307] perf interrupt took too long (2510 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
ravi
  • 291
You need to disable Secure Boot in BIOS settings.
See this question for more details.
The vboxdrv is not signed and Secure Boot does not let to load it.
Pilot6
  • 92,041
-1
You should prefer the version maintained by Ubuntu APT unless you have special needs. Install VirtualBox using APT:
sudo apt-get install virtualbox
Melebius
  • 11,750
