I am trying to open 139GB volume and 73GB volume in files. I am using UNUNTU 14.04. Why am I getting the following error:
Unable to access “139 GB Volume”
Error mounting /dev/sda4 at /media/admin123/9CC66C3CC66C1932:
Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sda4" "/media/admin123/9CC66C3CC66C1932"'
exited with non-zero exit status 14:
The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda4': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
naveen
  • 13
First open terminal and run this.
sudo apt-get install ntfs-3g
NTFS-3G is a stable, full-featured, read-write NTFS driver for Linux,
then run this command on the terminal to fix your NTFS partition. Replace XY with your partion name (sda4) - (Then the command for your partition is -- sudo ntfsfix /dev/sda4)
sudo ntfsfix /dev/XY
