I Would do this:
Change to ROOT mode from a Live CD/USB Preferrably, if not it will still work from a dual-booted Linux install. Open a terminal and type:
sudo -i
Then, find out which partition is your Windows via this command:
fdisk -l
Mine shows this:
/dev/sda1 * 2048 206847 204800 100M 7 HPFS/NTFS/exFAT
/dev/sda2 206848 240818175 240611328 114.8G 7 HPFS/NTFS/exFAT
/dev/sda3 240820224 312498175 71677952 34.2G 5 Extended
/dev/sda5 240822272 312498175 71675904 34.2G 7 HPFS/NTFS/exFAT
So in my case, /dev/sda1 is the recovery bootloader (windows). They vary in size, mine was 100M but I have seen others for example if the image was installed with MDT then they are bigger.
Next Disk Dump Backup the /dev/sda1 partition to a file, and store it anywhere you want. In this case I saved it in my root folder's home directory:
dd if=/dev/sda1 bs=16m of=/home/wubilover/BackupOfSda1-WinRecovPartition.dd
Remember that DD takes a long time to run, so wait until it finishes :)
That's it. To restore it, swap the if= and of= of the above command. :) Enjoy.
To Perform a FULL Backup of the entire Drive you can buy a USB Drive that is larger, and then save it to a .dd file in the bigger drive. This way if you break something, you can boot into the Live CD/USB and attach your external drive and restore.
Full Backup to external drive:
Boot into Live CD/USB wait for ubuntu to load and then open a terminal
Plug in your external drive which is LARGER then the internal drive, ensure that it is NTFS or EXT3 or higher so that it can hold the large file. This is confirmed via running the command:
gksudo gparted
Then go ahead and partition it to Ext3 or Ntfs (doesn’t matter, but if you are using windows i recommend ntfs)
Confirm that it is mounted via
df -kh
BACKUP THE HARD DRIVE to the EXTERNAL HARD DRIVE VIA (Notice the command is different from above):
dd if=/dev/sda bs=16m of=/media/MyUSBStick/BackupOfSda-TheEntireHD.dd
And... if something goes wrong you can RESTORE THE EXTERNAL HARD DRIVE's .dd file to the INTERNAL HARD DRIVE VIA (Notice the command is different from above):
dd bs=16m if=/media/MyUSBStick/BackupOfSda-TheEntireHD.dd of=/dev/sda
