For example I want to print long dash
I read that it's possible to do with numpad and code of Unicode of character, so I tried doing Alt+Shift+u + code, but without success.
Zanna
  • 72,312
Roman N
  • 429
You want Ctrl and not Alt. This
ctrl+shift+U then 2014enter
is giving me . Note that the output depends on your locale settings.
Zanna
  • 72,312
As stated in Ubuntu help page the proper way is the following:
  1. Press Ctrl + Shift + u
  2. Type in hexadecimal code for Unicode character you want to print
  3. Press enter
Alternative approach is to use printf (or echo -e) command in terminal and copy the output. For example, to print copyright sign do
$ printf "\u00a9"
$ echo -e "\u00a9"
Python can do the same, except you need to prepend u in the beginning of hexadecimal string. For instance,
$ python -c 'print u"\u00a9"  '
Command line ways can be useful in conjunction with xclip program, which basically copies stuff you give it to clipboard. For example, I could do :
 printf "\u00a9"  | xclip -sel clip
heemayl
  • 93,925
