How can I rearrange the operating systems installed on my computer in GRUB? I have Windows 10, Ubuntu 14.04 LTS, and Kubuntu 15.10. It prioritizes Kubuntu, with Ubuntu second, and Windows last. How can I make it so that Windows is at the top?
The easiest way to customize the entries in GRUB's boot menu is to use the tool grub-customizer.
Install it using these commands:
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
Then you can run grub-customizer. In the List configuration tab you can easily rename and reorder all available entries.
More information about grub-customizer can be found at How do I customize the GRUB 2 menu?.
Byte Commander
  • 110,243
