FINAL UPDATE : fixed it on my own.
I'm unable to launch steam , not from its icon in the dash , or from command line. i installed steam from the offical steampowered website since for some reason its not in the ubuntu 16 software center.
i installed it , it seemed to install ok. but it refused to launch when i tried from the dash. This shows what happened when i attempt to launch from command line.
Update : i have just recently removed the .steam folder , since im also unable to uninstall steam as well.
Update 2 : also LD_PRELOAD='/usr/$LIB/libstdc++.so.6' steam does not fix this issue at all , since no games will work nor will steam launch properly with this fix anyway.
Update 3 : after a half working steam purge command , i said screw it , and tried to install steam once more , here is the results. attempted to purge , seemed to only half work , so i said screw it , and tried to install it once more , and this is what happened
sudo apt install steam
[sudo] password for swaganater:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  linux-headers-4.4.0-21 linux-headers-4.4.0-21-generic
  linux-image-4.4.0-21-generic linux-image-extra-4.4.0-21-generic
Use 'sudo apt autoremove' to remove them.
The following NEW packages will be installed:
  steam:i386
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 874 kB of archives.
After this operation, 2,662 kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu xenial/multiverse i386 steam i386 1:1.0.0.48-1ubuntu3 [874 kB]
Fetched 874 kB in 0s (2,214 kB/s)
Preconfiguring packages ...
Selecting previously unselected package steam:i386.
(Reading database ... 253897 files and directories currently installed.)
Preparing to unpack .../steam_1%3a1.0.0.48-1ubuntu3_i386.deb ...
Unpacking steam:i386 (1:1.0.0.48-1ubuntu3) ...
Processing triggers for man-db (2.7.5-1) ...
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ...
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160523-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for desktop-file-utils (0.22-1ubuntu5) ...
Processing triggers for mime-support (3.59ubuntu1) ...
Setting up steam:i386 (1:1.0.0.48-1ubuntu3) ...
swaganater@Kenney4Linux:~$ steam
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
[2016-07-17 16:06:02] Startup - updater built Jun 16 2014 11:16:02
[2016-07-17 16:06:02] Verifying installation...
[2016-07-17 16:06:02] Unable to read and verify install manifest /home/swaganater/.steam/package/steam_client_ubuntu12.installed
[2016-07-17 16:06:02] Verification complete
[2016-07-17 16:06:02] Downloading Update...
[2016-07-17 16:06:02] Checking for available update...
[2016-07-17 16:06:03] Package file tenfoot_misc_all.zip.b9c015520018655499338cfc2c3a3159e28bbe14 missing or incorrect size
[2016-07-17 16:06:03] Package file tenfoot_dicts_all.zip.c74a3a9beb77a280cfd8761b901a80ed0f6a3173 missing or incorrect size
[2016-07-17 16:06:03] Package file tenfoot_fonts_all.zip.vz.b99d15e7a78b99cea4d0abb6c3f3badc0c6ad441_12073430 missing or incorrect size
[2016-07-17 16:06:03] Package file tenfoot_ambientsounds_all.zip.20ccff954777943069dd2c57576216f5f1db7389 missing or incorrect size
[2016-07-17 16:06:03] Package file tenfoot_sounds_all.zip.vz.7a3cc0ba5f5309183bca660227b8e0afa9922629_1223056 missing or incorrect size
[2016-07-17 16:06:03] Package file tenfoot_images_all.zip.vz.5d8dd353339a219454359b8b96832f22383b197f_23726084 missing or incorrect size
[2016-07-17 16:06:03] Package file tenfoot_all.zip.vz.e0a2fe024bd79e244560aa7b70b005eb85556472_1996073 missing or incorrect size
[2016-07-17 16:06:03] Package file resources_misc_all.zip.vz.5b8f09b1f407d80780688930b071e340fe22600d_2028216 missing or incorrect size
[2016-07-17 16:06:03] Package file resources_all.zip.vz.2d17031b733668c91d46c5460e09fe657d5f12d5_5010069 missing or incorrect size
[2016-07-17 16:06:03] Package file strings_en_all.zip.1079b38e274866fd7f8a52f1bc37a9cfd106e63d missing or incorrect size
[2016-07-17 16:06:03] Package file strings_all.zip.vz.647646aa643b76fd21ee5766cc52142308bf855e_1960475 missing or incorrect size
[2016-07-17 16:06:03] Package file remoteui_all.zip.vz.c3eceeaa19b297032eb8511f44f7f9a49bfdfe01_141152 missing or incorrect size
[2016-07-17 16:06:03] Package file public_all.zip.vz.c7767235236991fa627ebe4db03f97b171b643b8_792006 missing or incorrect size
[2016-07-17 16:06:03] Package file bins_ubuntu12.zip.vz.cceda6b84f1293bee16ebc9e8039ff98ffb73893_14829126 missing or incorrect size
[2016-07-17 16:06:03] Package file bins_pub_ubuntu12.zip.vz.e87445bc7c2dd4f8a3506783c3a5aeb62e8f8bd1_9030239 missing or incorrect size
[2016-07-17 16:06:03] Package file bins_sdk_ubuntu12.zip.vz.bdf2b7f5d46b352b78fbc7b4782ab8482d6d2459_9441387 missing or incorrect size
[2016-07-17 16:06:03] Package file bins_codecs_ubuntu12.zip.vz.11b6edae15c9060d91c0730ecbdad978a1bc7f0a_1830793 missing or incorrect size
[2016-07-17 16:06:03] Package file bins_misc_ubuntu12.zip.9e5c4f09c8cbdfb1b04cc8d0c93da2fee3b09bb1 missing or incorrect size
[2016-07-17 16:06:03] Package file webkit_ubuntu12.zip.vz.c8fc55b3a22afbfcaff30125993341cb37eca008_31272883 missing or incorrect size
[2016-07-17 16:06:03] Package file miles_ubuntu12.zip.vz.1b7a19905752a14821fcba42b49fe1a1ed6ba836_299743 missing or incorrect size
[2016-07-17 16:06:03] Package file sdl2_ubuntu12.zip.vz.f6390a991816501f796aa5cb4c21fc0c13aa4f72_288246 missing or incorrect size
[2016-07-17 16:06:03] Package file steam_ubuntu12.zip.vz.919f96220bae42fc7bf536ba0d3bc68b02d65de6_1307957 missing or incorrect size
[2016-07-17 16:06:03] Package file runtime_part0_ubuntu12.zip.6f3376e364f4ce8cf04392af838cded2c254d68c missing or incorrect size
[2016-07-17 16:06:03] Package file runtime_part1_ubuntu12.zip.6d3fe6fa3df74ddee0ea944ab024648f3d3179a8 missing or incorrect size
[2016-07-17 16:06:03] Downloading update (0 of 245,939 KB)...
[2016-07-17 16:06:03] Downloading update (1,437 of 245,939 KB)...
[2016-07-17 16:06:03] Downloading update (5,366 of 245,939 KB)...
[2016-07-17 16:06:03] Downloading update (9,133 of 245,939 KB)...
[2016-07-17 16:06:04] Downloading update (12,954 of 245,939 KB)...
[2016-07-17 16:06:04] Downloading update (16,875 of 245,939 KB)...
[2016-07-17 16:06:04] Downloading update (20,673 of 245,939 KB)...
[2016-07-17 16:06:04] Downloading update (24,216 of 245,939 KB)...
[2016-07-17 16:06:05] Downloading update (27,751 of 245,939 KB)...
[2016-07-17 16:06:05] Downloading update (31,689 of 245,939 KB)...
[2016-07-17 16:06:05] Downloading update (35,410 of 245,939 KB)...
[2016-07-17 16:06:05] Downloading update (39,339 of 245,939 KB)...
[2016-07-17 16:06:06] Downloading update (43,091 of 245,939 KB)...
[2016-07-17 16:06:06] Downloading update (47,018 of 245,939 KB)...
[2016-07-17 16:06:06] Downloading update (50,970 of 245,939 KB)...
[2016-07-17 16:06:06] Downloading update (54,510 of 245,939 KB)...
[2016-07-17 16:06:07] Downloading update (58,090 of 245,939 KB)...
[2016-07-17 16:06:07] Downloading update (61,214 of 245,939 KB)...
[2016-07-17 16:06:07] Downloading update (63,532 of 245,939 KB)...
[2016-07-17 16:06:08] Downloading update (65,917 of 245,939 KB)...
[2016-07-17 16:06:08] Downloading update (67,631 of 245,939 KB)...
[2016-07-17 16:06:08] Downloading update (69,510 of 245,939 KB)...
[2016-07-17 16:06:08] Downloading update (71,743 of 245,939 KB)...
[2016-07-17 16:06:09] Downloading update (73,441 of 245,939 KB)...
[2016-07-17 16:06:09] Downloading update (75,380 of 245,939 KB)...
[2016-07-17 16:06:09] Downloading update (77,602 of 245,939 KB)...
[2016-07-17 16:06:09] Downloading update (79,677 of 245,939 KB)...
[2016-07-17 16:06:10] Downloading update (81,921 of 245,939 KB)...
[2016-07-17 16:06:10] Downloading update (84,829 of 245,939 KB)...
[2016-07-17 16:06:10] Downloading update (86,845 of 245,939 KB)...
[2016-07-17 16:06:10] Downloading update (88,703 of 245,939 KB)...
[2016-07-17 16:06:11] Downloading update (90,704 of 245,939 KB)...
[2016-07-17 16:06:11] Downloading update (92,350 of 245,939 KB)...
[2016-07-17 16:06:11] Downloading update (94,357 of 245,939 KB)...
[2016-07-17 16:06:11] Downloading update (96,594 of 245,939 KB)...
[2016-07-17 16:06:12] Downloading update (98,445 of 245,939 KB)...
[2016-07-17 16:06:12] Downloading update (100,180 of 245,939 KB)...
[2016-07-17 16:06:12] Downloading update (102,523 of 245,939 KB)...
[2016-07-17 16:06:13] Downloading update (105,140 of 245,939 KB)...
[2016-07-17 16:06:13] Downloading update (106,559 of 245,939 KB)...
[2016-07-17 16:06:13] Downloading update (108,226 of 245,939 KB)...
[2016-07-17 16:06:13] Downloading update (109,993 of 245,939 KB)...
[2016-07-17 16:06:14] Downloading update (112,212 of 245,939 KB)...
[2016-07-17 16:06:14] Downloading update (114,191 of 245,939 KB)...
[2016-07-17 16:06:14] Downloading update (116,312 of 245,939 KB)...
[2016-07-17 16:06:14] Downloading update (118,781 of 245,939 KB)...
[2016-07-17 16:06:15] Downloading update (120,983 of 245,939 KB)...
[2016-07-17 16:06:15] Downloading update (122,932 of 245,939 KB)...
[2016-07-17 16:06:15] Downloading update (124,658 of 245,939 KB)...
[2016-07-17 16:06:15] Downloading update (126,421 of 245,939 KB)...
[2016-07-17 16:06:16] Downloading update (127,959 of 245,939 KB)...
[2016-07-17 16:06:16] Downloading update (129,640 of 245,939 KB)...
[2016-07-17 16:06:16] Downloading update (131,699 of 245,939 KB)...
[2016-07-17 16:06:16] Downloading update (133,577 of 245,939 KB)...
[2016-07-17 16:06:17] Downloading update (135,751 of 245,939 KB)...
[2016-07-17 16:06:17] Downloading update (137,248 of 245,939 KB)...
[2016-07-17 16:06:17] Downloading update (139,178 of 245,939 KB)...
[2016-07-17 16:06:17] Downloading update (140,872 of 245,939 KB)...
[2016-07-17 16:06:18] Downloading update (142,577 of 245,939 KB)...
[2016-07-17 16:06:18] Downloading update (144,575 of 245,939 KB)...
[2016-07-17 16:06:18] Downloading update (145,941 of 245,939 KB)...
[2016-07-17 16:06:18] Downloading update (147,583 of 245,939 KB)...
[2016-07-17 16:06:19] Downloading update (149,509 of 245,939 KB)...
[2016-07-17 16:06:19] Downloading update (151,095 of 245,939 KB)...
[2016-07-17 16:06:19] Downloading update (152,822 of 245,939 KB)...
[2016-07-17 16:06:19] Downloading update (154,335 of 245,939 KB)...
[2016-07-17 16:06:20] Downloading update (156,021 of 245,939 KB)...
[2016-07-17 16:06:20] Downloading update (157,819 of 245,939 KB)...
[2016-07-17 16:06:20] Downloading update (159,455 of 245,939 KB)...
[2016-07-17 16:06:20] Downloading update (161,074 of 245,939 KB)...
[2016-07-17 16:06:21] Downloading update (162,582 of 245,939 KB)...
[2016-07-17 16:06:21] Downloading update (164,328 of 245,939 KB)...
[2016-07-17 16:06:21] Downloading update (166,075 of 245,939 KB)...
[2016-07-17 16:06:21] Downloading update (167,701 of 245,939 KB)...
[2016-07-17 16:06:22] Downloading update (169,095 of 245,939 KB)...
[2016-07-17 16:06:22] Downloading update (170,479 of 245,939 KB)...
[2016-07-17 16:06:22] Downloading update (172,400 of 245,939 KB)...
[2016-07-17 16:06:22] Downloading update (174,230 of 245,939 KB)...
[2016-07-17 16:06:23] Downloading update (176,167 of 245,939 KB)...
[2016-07-17 16:06:23] Downloading update (177,937 of 245,939 KB)...
[2016-07-17 16:06:23] Downloading update (179,650 of 245,939 KB)...
[2016-07-17 16:06:23] Downloading update (181,424 of 245,939 KB)...
[2016-07-17 16:06:24] Downloading update (182,997 of 245,939 KB)...
[2016-07-17 16:06:24] Downloading update (184,508 of 245,939 KB)...
[2016-07-17 16:06:24] Downloading update (186,351 of 245,939 KB)...
[2016-07-17 16:06:24] Downloading update (187,519 of 245,939 KB)...
[2016-07-17 16:06:25] Downloading update (189,278 of 245,939 KB)...
[2016-07-17 16:06:25] Downloading update (190,944 of 245,939 KB)...
[2016-07-17 16:06:25] Downloading update (192,636 of 245,939 KB)...
[2016-07-17 16:06:25] Downloading update (194,554 of 245,939 KB)...
[2016-07-17 16:06:26] Downloading update (196,406 of 245,939 KB)...
[2016-07-17 16:06:26] Downloading update (197,925 of 245,939 KB)...
[2016-07-17 16:06:26] Downloading update (199,618 of 245,939 KB)...
[2016-07-17 16:06:26] Downloading update (201,494 of 245,939 KB)...
[2016-07-17 16:06:27] Downloading update (202,460 of 245,939 KB)...
[2016-07-17 16:06:27] Downloading update (204,256 of 245,939 KB)...
[2016-07-17 16:06:27] Downloading update (205,218 of 245,939 KB)...
[2016-07-17 16:06:28] Downloading update (206,179 of 245,939 KB)...
[2016-07-17 16:06:57] Shutdown
[2016-07-17 16:07:01] Startup - updater built Jun 16 2014 11:16:02
[2016-07-17 16:07:01] Verifying installation...
[2016-07-17 16:07:01] Unable to read and verify install manifest /home/swaganater/.steam/package/steam_client_ubuntu12.installed
[2016-07-17 16:07:01] Verification complete
[2016-07-17 16:07:01] Downloading Update...
[2016-07-17 16:07:01] Checking for available update...
[2016-07-17 16:07:01] Package file tenfoot_misc_all.zip.b9c015520018655499338cfc2c3a3159e28bbe14 missing or incorrect size
[2016-07-17 16:07:01] Package file tenfoot_dicts_all.zip.c74a3a9beb77a280cfd8761b901a80ed0f6a3173 missing or incorrect size
[2016-07-17 16:07:01] Package file tenfoot_fonts_all.zip.vz.b99d15e7a78b99cea4d0abb6c3f3badc0c6ad441_12073430 missing or incorrect size
[2016-07-17 16:07:01] Package file tenfoot_ambientsounds_all.zip.20ccff954777943069dd2c57576216f5f1db7389 missing or incorrect size
[2016-07-17 16:07:01] Package file tenfoot_sounds_all.zip.vz.7a3cc0ba5f5309183bca660227b8e0afa9922629_1223056 missing or incorrect size
[2016-07-17 16:07:01] Package file tenfoot_images_all.zip.vz.5d8dd353339a219454359b8b96832f22383b197f_23726084 missing or incorrect size
[2016-07-17 16:07:01] Package file tenfoot_all.zip.vz.e0a2fe024bd79e244560aa7b70b005eb85556472_1996073 missing or incorrect size
[2016-07-17 16:07:01] Package file resources_misc_all.zip.vz.5b8f09b1f407d80780688930b071e340fe22600d_2028216 missing or incorrect size
[2016-07-17 16:07:01] Package file resources_all.zip.vz.2d17031b733668c91d46c5460e09fe657d5f12d5_5010069 missing or incorrect size
[2016-07-17 16:07:01] Package file strings_en_all.zip.1079b38e274866fd7f8a52f1bc37a9cfd106e63d missing or incorrect size
[2016-07-17 16:07:01] Package file strings_all.zip.vz.647646aa643b76fd21ee5766cc52142308bf855e_1960475 missing or incorrect size
[2016-07-17 16:07:01] Package file remoteui_all.zip.vz.c3eceeaa19b297032eb8511f44f7f9a49bfdfe01_141152 missing or incorrect size
[2016-07-17 16:07:01] Package file public_all.zip.vz.c7767235236991fa627ebe4db03f97b171b643b8_792006 missing or incorrect size
[2016-07-17 16:07:01] Package file bins_ubuntu12.zip.vz.cceda6b84f1293bee16ebc9e8039ff98ffb73893_14829126 missing or incorrect size
[2016-07-17 16:07:01] Package file bins_pub_ubuntu12.zip.vz.e87445bc7c2dd4f8a3506783c3a5aeb62e8f8bd1_9030239 missing or incorrect size
[2016-07-17 16:07:01] Package file bins_sdk_ubuntu12.zip.vz.bdf2b7f5d46b352b78fbc7b4782ab8482d6d2459_9441387 missing or incorrect size
[2016-07-17 16:07:01] Package file bins_codecs_ubuntu12.zip.vz.11b6edae15c9060d91c0730ecbdad978a1bc7f0a_1830793 missing or incorrect size
[2016-07-17 16:07:01] Package file bins_misc_ubuntu12.zip.9e5c4f09c8cbdfb1b04cc8d0c93da2fee3b09bb1 missing or incorrect size
[2016-07-17 16:07:01] Package file webkit_ubuntu12.zip.vz.c8fc55b3a22afbfcaff30125993341cb37eca008_31272883 missing or incorrect size
[2016-07-17 16:07:01] Package file miles_ubuntu12.zip.vz.1b7a19905752a14821fcba42b49fe1a1ed6ba836_299743 missing or incorrect size
[2016-07-17 16:07:01] Package file sdl2_ubuntu12.zip.vz.f6390a991816501f796aa5cb4c21fc0c13aa4f72_288246 missing or incorrect size
[2016-07-17 16:07:01] Package file steam_ubuntu12.zip.vz.919f96220bae42fc7bf536ba0d3bc68b02d65de6_1307957 missing or incorrect size
[2016-07-17 16:07:01] Package file runtime_part0_ubuntu12.zip.6f3376e364f4ce8cf04392af838cded2c254d68c missing or incorrect size
[2016-07-17 16:07:01] Package file runtime_part1_ubuntu12.zip.6d3fe6fa3df74ddee0ea944ab024648f3d3179a8 missing or incorrect size
[2016-07-17 16:07:01] Downloading update (0 of 245,939 KB)...
[2016-07-17 16:07:01] Downloading update (1,416 of 245,939 KB)...
[2016-07-17 16:07:02] Downloading update (5,344 of 245,939 KB)...
[2016-07-17 16:07:02] Downloading update (9,126 of 245,939 KB)...
[2016-07-17 16:07:02] Downloading update (13,058 of 245,939 KB)...
[2016-07-17 16:07:02] Downloading update (16,961 of 245,939 KB)...
[2016-07-17 16:07:03] Downloading update (20,795 of 245,939 KB)...
[2016-07-17 16:07:03] Downloading update (24,624 of 245,939 KB)...
[2016-07-17 16:07:03] Downloading update (28,119 of 245,939 KB)...
[2016-07-17 16:07:03] Downloading update (32,386 of 245,939 KB)...
[2016-07-17 16:07:04] Downloading update (36,389 of 245,939 KB)...
[2016-07-17 16:07:04] Downloading update (39,917 of 245,939 KB)...
[2016-07-17 16:07:04] Downloading update (43,824 of 245,939 KB)...
[2016-07-17 16:07:04] Downloading update (47,721 of 245,939 KB)...
[2016-07-17 16:07:05] Downloading update (51,795 of 245,939 KB)...
[2016-07-17 16:07:05] Downloading update (56,021 of 245,939 KB)...
[2016-07-17 16:07:05] Downloading update (60,273 of 245,939 KB)...
[2016-07-17 16:07:05] Downloading update (63,941 of 245,939 KB)...
[2016-07-17 16:07:06] Downloading update (68,131 of 245,939 KB)...
[2016-07-17 16:07:06] Downloading update (72,369 of 245,939 KB)...
[2016-07-17 16:07:06] Downloading update (77,286 of 245,939 KB)...
[2016-07-17 16:07:07] Downloading update (82,097 of 245,939 KB)...
[2016-07-17 16:07:07] Downloading update (86,152 of 245,939 KB)...
[2016-07-17 16:07:07] Downloading update (89,679 of 245,939 KB)...
[2016-07-17 16:07:07] Downloading update (93,624 of 245,939 KB)...
[2016-07-17 16:07:08] Downloading update (97,539 of 245,939 KB)...
[2016-07-17 16:07:08] Downloading update (101,440 of 245,939 KB)...
[2016-07-17 16:07:08] Downloading update (104,978 of 245,939 KB)...
[2016-07-17 16:07:08] Downloading update (108,906 of 245,939 KB)...
[2016-07-17 16:07:09] Downloading update (112,809 of 245,939 KB)...
[2016-07-17 16:07:09] Downloading update (116,614 of 245,939 KB)...
[2016-07-17 16:07:09] Downloading update (120,356 of 245,939 KB)...
[2016-07-17 16:07:10] Downloading update (124,925 of 245,939 KB)...
[2016-07-17 16:07:10] Downloading update (128,852 of 245,939 KB)...
[2016-07-17 16:07:10] Downloading update (132,372 of 245,939 KB)...
[2016-07-17 16:07:10] Downloading update (136,341 of 245,939 KB)...
[2016-07-17 16:07:11] Downloading update (141,056 of 245,939 KB)...
[2016-07-17 16:07:11] Downloading update (145,062 of 245,939 KB)...
[2016-07-17 16:07:11] Downloading update (148,902 of 245,939 KB)...
[2016-07-17 16:07:12] Downloading update (151,347 of 245,939 KB)...
[2016-07-17 16:07:12] Downloading update (152,773 of 245,939 KB)...
[2016-07-17 16:07:12] Downloading update (154,611 of 245,939 KB)...
[2016-07-17 16:07:12] Downloading update (156,660 of 245,939 KB)...
[2016-07-17 16:07:13] Downloading update (158,666 of 245,939 KB)...
[2016-07-17 16:07:13] Downloading update (160,595 of 245,939 KB)...
[2016-07-17 16:07:13] Downloading update (162,391 of 245,939 KB)...
[2016-07-17 16:07:13] Downloading update (164,207 of 245,939 KB)...
[2016-07-17 16:07:14] Downloading update (166,191 of 245,939 KB)...
[2016-07-17 16:07:14] Downloading update (168,104 of 245,939 KB)...
[2016-07-17 16:07:14] Downloading update (170,157 of 245,939 KB)...
[2016-07-17 16:07:14] Downloading update (171,861 of 245,939 KB)...
[2016-07-17 16:07:15] Downloading update (173,736 of 245,939 KB)...
[2016-07-17 16:07:15] Downloading update (175,901 of 245,939 KB)...
[2016-07-17 16:07:15] Downloading update (177,509 of 245,939 KB)...
[2016-07-17 16:07:15] Downloading update (179,604 of 245,939 KB)...
[2016-07-17 16:07:16] Downloading update (181,424 of 245,939 KB)...
[2016-07-17 16:07:16] Downloading update (183,312 of 245,939 KB)...
[2016-07-17 16:07:16] Downloading update (185,246 of 245,939 KB)...
[2016-07-17 16:07:16] Downloading update (186,950 of 245,939 KB)...
[2016-07-17 16:07:17] Downloading update (189,193 of 245,939 KB)...
[2016-07-17 16:07:17] Downloading update (191,087 of 245,939 KB)...
[2016-07-17 16:07:17] Downloading update (192,885 of 245,939 KB)...
[2016-07-17 16:07:17] Downloading update (194,900 of 245,939 KB)...
[2016-07-17 16:07:18] Downloading update (196,434 of 245,939 KB)...
[2016-07-17 16:07:18] Downloading update (198,405 of 245,939 KB)...
[2016-07-17 16:07:18] Downloading update (201,488 of 245,939 KB)...
[2016-07-17 16:07:18] Downloading update (203,517 of 245,939 KB)...
[2016-07-17 16:07:19] Downloading update (205,046 of 245,939 KB)...
[2016-07-17 16:07:19] Downloading update (206,648 of 245,939 KB)...
[2016-07-17 16:07:19] Downloading update (208,504 of 245,939 KB)...
[2016-07-17 16:07:19] Downloading update (210,425 of 245,939 KB)...
[2016-07-17 16:07:20] Downloading update (212,310 of 245,939 KB)...
[2016-07-17 16:07:20] Downloading update (214,084 of 245,939 KB)...
[2016-07-17 16:07:20] Downloading update (216,104 of 245,939 KB)...
[2016-07-17 16:07:20] Downloading update (218,076 of 245,939 KB)...
[2016-07-17 16:07:21] Downloading update (219,793 of 245,939 KB)...
[2016-07-17 16:07:21] Downloading update (221,874 of 245,939 KB)...
[2016-07-17 16:07:21] Downloading update (223,662 of 245,939 KB)...
[2016-07-17 16:07:21] Downloading update (225,400 of 245,939 KB)...
[2016-07-17 16:07:22] Downloading update (227,181 of 245,939 KB)...
[2016-07-17 16:07:22] Downloading update (228,812 of 245,939 KB)...
[2016-07-17 16:07:22] Downloading update (230,444 of 245,939 KB)...
[2016-07-17 16:07:22] Downloading update (232,367 of 245,939 KB)...
[2016-07-17 16:07:23] Downloading update (233,856 of 245,939 KB)...
[2016-07-17 16:07:23] Downloading update (235,852 of 245,939 KB)...
[2016-07-17 16:07:23] Downloading update (237,541 of 245,939 KB)...
[2016-07-17 16:07:23] Downloading update (239,537 of 245,939 KB)...
[2016-07-17 16:07:24] Downloading update (241,374 of 245,939 KB)...
[2016-07-17 16:07:24] Downloading update (243,316 of 245,939 KB)...
[2016-07-17 16:07:24] Downloading update (244,520 of 245,939 KB)...
[2016-07-17 16:07:25] Downloading update (245,939 of 245,939 KB)...
[2016-07-17 16:07:25] Download Complete.
[2016-07-17 16:07:25] uninstalled manifest found in /home/swaganater/.steam/package/steam_client_ubuntu12 (1).
[2016-07-17 16:07:25] Extracting package...
[2016-07-17 16:07:39] Installing update...
[2016-07-17 16:07:40] Cleaning up...
[2016-07-17 16:07:40] Update complete, launching...
[2016-07-17 16:07:40] Shutdown
Running Steam on ubuntu 16.04 64-bit
STEAM_RUNTIME is enabled automatically
[2016-07-17 16:07:49] Startup - updater built Jul  8 2016 21:43:51
SteamUpdateUI: An X Error occurred
X Error of failed request:  BadValue (integer parameter out of range for operation)
[ Old ]
Installing breakpad exception handler for appid(steam)/version(0)
libGL error: unable to load driver: nouveau_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: nouveau
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
I have checked the forums and other questions here on Ask Ubuntu, and none of them helped get it working.
Is there anyway to fix this , or am i going to have to install an older verison of ubuntu?
First you're going to want to completely remove any leftover steam-related files using these command lines:
https://askubuntu.com/a/217875/569100
Then re-install steam using this: https://askubuntu.com/a/556039/569100
If steam still doesn't work after all that, use this code in the terminal: LD_PRELOAD='/usr/$LIB/libstdc++.so.6' steam
HelpMeee
  • 648
