I've only had Ubuntu for a couple of months so please be gentle as I'm a complete noob here. I'm getting the boot full warning that seems to have plagued many on here, but none of the answers seem to work. I have tried removing old kernels from the terminal and with synaptic. It seems as though many are half installed, but they cannot be repaired as there is no room; bit of a vicious circle. I hope this makes sense to someone.
Please help,
Matt
mitchell@mitchell-Inspiron-530:~$ sudo apt-get install -f
Reading package lists... Done
The following packages will be REMOVED
linux-image-extra-4.2.0-30-generic linux-image-extra-4.2.0-34-generic
linux-image-extra-4.2.0-35-generic linux-image-extra-4.2.0-36-generic
linux-image-extra-4.2.0-41-generic
0 to upgrade, 0 to newly install, 5 to remove and 0 not to upgrade.
8 not fully installed or removed.
After this operation, 808 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 216763 files and directories currently installed.)
Removing linux-image-extra-4.2.0-30-generic (4.2.0-30.36~14.04.1) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.2.0-30-generic /boot/vmlinuz-4.2.0-30-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.2.0-30-generic /boot/vmlinuz-4.2.0-30-generic
update-initramfs: Generating /boot/initrd.img-4.2.0-30-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-4.2.0-30-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-extra-4.2.0-30-generic (--remove):
subprocess installed post-removal script returned error exit status 1
Removing linux-image-extra-4.2.0-34-generic (4.2.0-34.39~14.04.1) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.2.0-34-generic /boot/vmlinuz-4.2.0-34-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.2.0-34-generic /boot/vmlinuz-4.2.0-34-generic
update-initramfs: Generating /boot/initrd.img-4.2.0-34-generic
update-initramfs: failed for /boot/initrd.img-4.2.0-34-generic with 1.
dpkg: error processing package linux-image-extra-4.2.0-34-generic (--remove):
Removing linux-image-extra-4.2.0-35-generic (4.2.0-35.40~14.04.1) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.2.0-35-generic /boot/vmlinuz-4.2.0-35-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.2.0-35-generic /boot/vmlinuz-4.2.0-35-generic
update-initramfs: Generating /boot/initrd.img-4.2.0-35-generic
update-initramfs: failed for /boot/initrd.img-4.2.0-35-generic with 1.
dpkg: error processing package linux-image-extra-4.2.0-35-generic (--remove):
Removing linux-image-extra-4.2.0-36-generic (4.2.0-36.42~14.04.1) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.2.0-36-generic /boot/vmlinuz-4.2.0-36-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.2.0-36-generic /boot/vmlinuz-4.2.0-36-generic
update-initramfs: Generating /boot/initrd.img-4.2.0-36-generic
update-initramfs: failed for /boot/initrd.img-4.2.0-36-generic with 1.
dpkg: error processing package linux-image-extra-4.2.0-36-generic (--remove):
No apport report written because MaxReports has already been reached
Removing linux-image-extra-4.2.0-41-generic (4.2.0-41.48~14.04.1) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.2.0-41-generic /boot/vmlinuz-4.2.0-41-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.2.0-41-generic /boot/vmlinuz-4.2.0-41-generic
update-initramfs: Generating /boot/initrd.img-4.2.0-41-generic
update-initramfs: failed for /boot/initrd.img-4.2.0-41-generic with 1.
dpkg: error processing package linux-image-extra-4.2.0-41-generic (--remove):
E: Sub-process /usr/bin/dpkg returned an error code (1)}
Ok not sure about how I edit this post; hopefully this info is what
you asked for Phil.
mitchell@mitchell-Inspiron-530:~$ dpkg -l | grep linux-image pi
linux-image-4.2.0-30-generic
4.2.0-30.36~14.04.1 amd64
Linux kernel image for version 4.2.0 on 64 bit x86 SMP ii
linux-image-4.2.0-34-generic
4.2.0-34.39~14.04.1 amd64
linux-image-4.2.0-35-generic
4.2.0-35.40~14.04.1 amd64
linux-image-4.2.0-36-generic
4.2.0-36.42~14.04.1 amd64
Linux kernel image for version 4.2.0 on 64 bit x86 SMP pi
linux-image-4.2.0-38-generic
4.2.0-38.45~14.04.1 amd64
linux-image-4.2.0-41-generic
4.2.0-41.48~14.04.1 amd64
linux-image-4.2.0-42-generic
4.2.0-42.49~14.04.1 amd64
Linux kernel image for version 4.2.0 on 64 bit x86 SMP rH
Linux kernel extra modules for version 4.2.0 on 64 bit x86 SMP rH
Linux kernel extra modules for version 4.2.0 on 64 bit x86 SMP ii
linux-image-extra-4.2.0-38-generic
Linux kernel extra modules for version 4.2.0 on 64 bit x86 SMP iF
linux-image-extra-4.2.0-42-generic
Linux kernel extra modules for version 4.2.0 on 64 bit x86 SMP iU
linux-image-generic-lts-wily
4.2.0.42.34
amd64 Generic Linux kernel image`
mitchell@mitchell-Inspiron-530:~$ ls -l /boot total 230705
-rw-r--r-- 1 root root 1312643 Feb 26 20:36 abi-4.2.0-30-generic
-rw-r--r-- 1 root root 1312645 Mar 11 13:17 abi-4.2.0-34-generic
-rw-r--r-- 1 root root 1313029 Mar 18 18:14 abi-4.2.0-35-generic
-rw-r--r-- 1 root root 1313407 May 13 22:55 abi-4.2.0-36-generic
-rw-r--r-- 1 root root 1313411 Jun 9 11:51 abi-4.2.0-38-generic
-rw-r--r-- 1 root root 1313640 Jun 24 19:37 abi-4.2.0-41-generic
-rw-r--r-- 1 root root 1313590 Jun 29 23:31 abi-4.2.0-42-generic
-rw-r--r-- 1 root root 184896 Feb 26 20:36 config-4.2.0-30-generic
-rw-r--r-- 1 root root 184896 Mar 11 13:17 config-4.2.0-34-generic
-rw-r--r-- 1 root root 184896 Mar 18 18:14 config-4.2.0-35-generic
-rw-r--r-- 1 root root 184896 May 13 22:55 config-4.2.0-36-generic
-rw-r--r-- 1 root root 184897 Jun 9 11:51 config-4.2.0-38-generic
-rw-r--r-- 1 root root 184897 Jun 24 19:37 config-4.2.0-41-generic
-rw-r--r-- 1 root root 184934 Jun 29 23:31 config-4.2.0-42-generic
drwxr-xr-x 5 root root 1024 Jul 16 12:12 grub
-rw-r--r-- 1 root root 3325217 Jul 5 17:58 initrd.img-4.2.0-27-generic
-rw-r--r-- 1 root root 20661169 Mar 13 13:08 initrd.img-4.2.0-30-generic
-rw-r--r-- 1 root root 20661076 Mar 14 17:44 initrd.img-4.2.0-34-generic
-rw-r--r-- 1 root root 20678829 Apr 9 18:35 initrd.img-4.2.0-35-generic
-rw-r--r-- 1 root root 21373450 Jun 19 13:36 initrd.img-4.2.0-36-generic
-rw-r--r-- 1 root root 21372333 Jun 19 13:36 initrd.img-4.2.0-38-generic
-rw-r--r-- 1 root root 21374089 Jul 5 17:58 initrd.img-4.2.0-41-generic
-rw-r--r-- 1 root root 21372772 Jul 15 18:17 initrd.img-4.2.0-42-generic drwx------ 2 root root 12288 Mar 13
11:13 lost+found
-rw-r--r-- 1 root root 176500 Mar 12 2014 memtest86+.bin
-rw-r--r-- 1 root root 178176 Mar 12 2014 memtest86+.elf
-rw-r--r-- 1 root root 178680 Mar 12 2014 memtest86+_multiboot.bin
-rw------- 1 root root 3757557 Feb 26 20:36 System.map-4.2.0-30-generic
-rw------- 1 root root 3757656 Mar 11 13:17 System.map-4.2.0-34-generic
-rw------- 1 root root 3758162 Mar 18 18:14 System.map-4.2.0-35-generic
-rw------- 1 root root 3758996 May 13 22:55 System.map-4.2.0-36-generic
-rw------- 1 root root 3759342 Jun 9 11:51 System.map-4.2.0-38-generic
-rw------- 1 root root 3759492 Jun 24 19:37 System.map-4.2.0-41-generic
-rw------- 1 root root 3760051 Jun 29 23:31 System.map-4.2.0-42-generic
-rw------- 1 root root 6715312 Feb 26 20:36 vmlinuz-4.2.0-30-generic
-rw------- 1 root root 6716080 Mar 11 13:17 vmlinuz-4.2.0-34-generic
-rw------- 1 root root 6731856 Mar 18 18:14 vmlinuz-4.2.0-35-generic
-rw------- 1 root root 6732816 May 13 22:55 vmlinuz-4.2.0-36-generic
-rw------- 1 root root 6732272 Jun 9 11:51 vmlinuz-4.2.0-38-generic
-rw------- 1 root root 6734768 Jun 24 19:37 vmlinuz-4.2.0-41-generic
-rw------- 1 root root 6736496 Jun 29 23:31 vmlinuz-4.2.0-42-generic`
mitchell@mitchell-Inspiron-530:~$ df -h
Filesystem Size Used Avail Use% Mounted on udev 2.0G 4.0K 2.0G 1% /dev tmpfs
396M 1.5M 394M 1% /run /dev/dm-0 290G 50G 225G 19% /
none 4.0K 0 4.0K 0% /sys/fs/cgroup none
5.0M 0 5.0M 0% /run/lock none 2.0G 76K 2.0G 1% /run/shm none 100M 40K 100M 1% /run/user /dev/sda1
236M 234M 0 100% /boot
mitchell@mitchell-Inspiron-530:~$ uname -r
4.2.0-42-generic`
