11
I've searched this and can only find older threads and for older versions of Linux.
I want to install MAME (arcade emulator) on Ubuntu 16.04. Anyone that has actually got MAME working on Ubuntu 16.04 please let me know the exact process. Thanks.
You can get very clear instructions at http://sdlmame.wallyweek.org/repository/ on how to install MAME via an unofficial PPA, which I copy verbatim here because there isn't anything to add:
Open a terminal window (commands may be typed directly or pasted into it) and:
  1. Remove old sdlmame repositories (if any):
    sudo rm -f /etc/apt/sources.list.d/sdlmame4ubuntu.*
  2. Add the main repository for unofficial builds:
    sudo add-apt-repository ppa:c.falco/mame
  3. (optionally) add the repository for "u"(nstable) builds:
    (Skip this step to stick with main, stable, not-"u" releases!)
    sudo add-apt-repository ppa:c.falco/umame
  4. Now update the information on your box:
    sudo apt-get update
  5. Finally install the package from the repository:
    sudo apt-get install mame
edwinksl
  • 24,109
I came across this video on YouTube which shows additional configuration steps. Not tested by myself so take with a grain of salt. In summary:
sudo apt-get update
Then edit the configuration file to set your default rompath
gedit ~/.mame/mame.ini
And change the rompath line if necessary. The video shows it as
rompath     $HOME/mame/roms;/usr/local/share/games/mame/roms
Don't follow the video's advice to use sudo nautilus - that's a very bad idea. If you really need to open nautilus as root (which should not often be the case, do
sudo -i
nautilus <some directory> &
and when done, remember to type
exit
in the terminal to drop privileges
Zanna
  • 72,312
Alex
