I am running ubuntu 16.04, and when I try to install a program using apt-get install (really any program, but take git-all for example), I get the following error:
start: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
the full error stack is below:
sudo apt-get install git-all
Reading package lists... Done
Building dependency tree
git-all is already the newest version (1:2.7.4-0ubuntu1).
0 upgraded, 0 newly installed, 0 to remove and 283 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up runit (2.1.2-3ubuntu1) ...
dpkg: error processing package runit (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of git-daemon-run:
git-daemon-run depends on runit; however:
Package runit is not configured yet.
dpkg: error processing package git-daemon-run (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
runit
git-daemon-run
I realize this error has been posted around the internet for over a year now, and I know that it is caused by the fact that upstart was replaced by systemd, and but not all programs have been switched to using systemd. But none of the fixes work for me.
There is this post, which has been flagged as potentially dangerous and has caused many people to be unable to boot their system: "nesono.com/node/368"
Then there is this post: "vivid - failed to connect to upstart: connection refused". The "recommended fix" is to switch all systems to systemd manually according to this link: "https://wiki.ubuntu.com/SystemdForUpstartUsers". But the linked page does not actually show how to switch everything to systemd. And the "quick fix" option (running sudo apt-get install upstart-sysv to switch back to upstart), which appears to actually be the one recommended and implemented by most people experiencing this problem, does not work for me either because again, apt-get gives me an upstart error.
"https://www.nesono.com/node/368" Also suggests going into GRUB2 and using the bootloader to start the system using upstart. However, this is not an option for me in the bootloader, which leads me to believe I evidently do not have upstart on my computer (yet again another failed fix).
There is also a similar issue posted here that appears to be unresolved (no accepted answer): "askubuntu.com/questions/728581"
Please help!
