How can we install a telnet client in Ubuntu 16.04? With this command, we can install a telnet server:
sudo apt-get install xinetd telnetd
But can a telnet client be installed without a telnet server? A telnet server can be dangerous.
apt-get update
apt-get install telnet
This is a valid question BTW. Do not install the telnet server, ever. Also the telnet client is not included by default in many distros. For instance it is very common in docker-land to face the need of installing several tools that are taken otherwise for granted. For example, Official OS docker images most likely will be shipped with a shell and its built-ins. Telnet will not be shipped in any of those.
A lot of docker images don't come with standard tools like vim, ping & telnet. You may need to install them explicitly.
sudo apt-get update && apt-get install telnet
You shouldn't need to install any packages; a telnet client should come standard with Ubuntu. Just open a terminal window (Alt + Ctrl + T) and use the telnet command (for help, type man telnet)
