I want to get Emerald Theme Manager to work in Ubuntu 11.10 and activate its themes. Also, I want to be able to switch between Emerald themes and the originally installed (Metacity) themes. How do I do it?
Asked
Active
Viewed 2.3k times
Another solution is to install emerald version 0.9.5 via PPA :
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
sudo apt-get install emerald
After installation, press Alt+F2 and type emerald --replace.
And if u want to get back to gtk themes press Alt+F2 and type gtk-window-decorator --replace.
source: here
Black Block
- 5,139
Since emerald is not in the Ubuntu repos in 11.10, this thread has a workaround to install emerald. To use emerald, press Alt+F2 then type emerald --replace. If you're going to stick with emerald, add the command to your startup applications. To go back to Metacity, type this: gtk-window-decorator --replace.
Knowledge Cube
- 14,911
Engels Peralta
- 539
