Before anyone says use the search function, I did, and I found a topic very similar (Installed wrong libc6-dev Version) so I will provide the same outputs from commands that were used there, but I'm too newb on ubuntu to adapt the solution to my problem :/
Onto the topic, I was installing some stuff onto my server and one post suggested tampering with the sources.list files, so I did and I knew it was a bad idea...
Fastforward to now I cant use apt-get install, apt-get upgrade or anything in apt due to it telling me the libc6 library is too new, and I don't know how to downgrade it because the dependencies are all mixed up :S Pls Help!
The following are outputs of commands I tried, which were also asked for by the OP of the other post:
Output of apt-get upgrade :
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 libc-bin : Depends: libc6 (< 2.20) but 2.22-13 is installed
 libc-l10n : Breaks: locales (< 2.21-1)
 libc6 : Breaks: locales (< 2.22)
E: Unmet dependencies. Try using -f.
Output of apt-cache policy libc6 libc6-dev locales :
Installed: 2.22-13
  Candidate: 2.23-1
  Version table:
     2.23-1 0
        500 http://httpredir.debian.org/debian/ sid/main amd64 Packages
 *** 2.22-13 0
        100 /var/lib/dpkg/status
     2.19-0ubuntu6.9 0
        500 http://mirrors.digitalocean.com/ubuntu/ trusty-updates/main amd64 Packages
        500 http://security.ubuntu.com/ubuntu/ trusty-security/main amd64 Packages
     2.19-0ubuntu6 0
        500 http://mirrors.digitalocean.com/ubuntu/ trusty/main amd64 Packages
libc6-dev:
  Installed: 2.22-13
  Candidate: 2.23-1
  Version table:
     2.23-1 0
 *** 2.22-13 0
     2.19-0ubuntu6.9 0
     2.19-0ubuntu6 0
locales:
  Installed: 2.13+git20120306-12.1
  Candidate: 2.23-1
  Version table:
     2.23-1 0
 *** 2.13+git20120306-12.1 0
     2.13+git20120306-12 0
Output of apt-get install libc6=2.19-0ubuntu6.7 libc6-dev=2.19-0ubuntu6.7 :
E: Version '2.19-0ubuntu6.7' for 'libc6' was not found
E: Version '2.19-0ubuntu6.7' for 'libc6-dev' was not found
Output of apt-cache policy libc-dev-bin libc-l10n libc6-dev libc6-i386 :
libc-dev-bin:
  Installed: 2.22-13
  Candidate: 2.23-1
  Version table:
     2.23-1 0
 *** 2.22-13 0
     2.19-0ubuntu6.9 0
     2.19-0ubuntu6 0
libc-l10n:
  Installed: 2.22-13
  Candidate: 2.23-1
  Version table:
     2.23-1 0
 *** 2.22-13 0
libc6-dev:
  Installed: 2.22-13
  Candidate: 2.23-1
  Version table:
     2.23-1 0
 *** 2.22-13 0
     2.19-0ubuntu6.9 0
     2.19-0ubuntu6 0
libc6-i386:
  Installed: (none)
  Candidate: 2.23-1
  Version table:
     2.23-1 0
     2.19-0ubuntu6.9 0
     2.19-0ubuntu6 0
Output of apt-get purge libc-l10n :
You might want to run 'apt-get -f install' to correct these:
 libc-bin : Depends: libc6 (< 2.20) but 2.22-13 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Output of apt-get install libc-dev-bin=2.19-0ubuntu6.7 libc6-dev=2.19-0ubuntu6.7 libc6-i386=2.19-0ubuntu6.7
E: Version '2.19-0ubuntu6.7' for 'libc-dev-bin' was not found
E: Version '2.19-0ubuntu6.7' for 'libc6-i386' was not found
Output of the final command that apparently fixed it for the other person sudo apt-get install libc6=2.19-0ubuntu6.7 libc6-dev=2.19-0ubuntu6.7 libc6-i386=2.19-0ubuntu6.7 libc-dev-bin=2.19-0ubuntu6.7 libc-bin=2.19-0ubuntu6.7 libc-l10n- :
I can see that it was "not found", but I have no idea how to fix this at all.
I also ran the following sudo apt-get install libc6=2.19-0ubuntu6.9 libc6-dev=2.19-0ubuntu6.9 libc6-i386=2.19-0ubuntu6.9 libc-dev-bin=2.19-0ubuntu6.9 libc-bin=2.19-0ubuntu6.9 libc-l10n- and it gave me :
E: Unable to locate package
Thank you very much for reading, hoping there is someone out there who can help.
P.S. apt-get update gives me this, I also have no idea what this all means :/
W: GPG error: http://httpredir.debian.org sid InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8B48AD6246925553 NO_PUBKEY 7638D0442B90D010
W: Ignoring Provides line with DepCompareOp for package dh-systemd
W: Ignoring Provides line with DepCompareOp for package libjpeg62
W: Ignoring Provides line with DepCompareOp for package php-psr-http-message-implementation
W: Ignoring Provides line with DepCompareOp for package php-psr-log-implementation
W: Ignoring Provides line with DepCompareOp for package php-seclib
W: Ignoring Provides line with DepCompareOp for package php-sabre-http
W: Ignoring Provides line with DepCompareOp for package php-math-biginteger
W: Ignoring Provides line with DepCompareOp for package pypy-cffi
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-min
Edit: Here is my sources.list file (something probably wrong here too):
deb-src http://httpredir.debian.org/debian sid main contrib non-free
deb http://httpredir.debian.org/debian sid main contrib non-free
## Note, this file is written by cloud-init on first boot of an instance
## modifications made here will not survive a re-bundle.
## if you wish to make changes you can:
## a.) add 'apt_preserve_sources_list: true' to /etc/cloud/cloud.cfg
##     or do the same in user-data
## b.) add sources in /etc/apt/sources.list.d
## c.) make changes to template file /etc/cloud/templates/sources.list.tmpl
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://mirrors.digitalocean.com/ubuntu trusty main restricted
deb-src http://mirrors.digitalocean.com/ubuntu trusty main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://mirrors.digitalocean.com/ubuntu trusty-updates main restricted
deb-src http://mirrors.digitalocean.com/ubuntu trusty-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://mirrors.digitalocean.com/ubuntu trusty universe
deb-src http://mirrors.digitalocean.com/ubuntu trusty universe
deb http://mirrors.digitalocean.com/ubuntu trusty-updates universe
deb-src http://mirrors.digitalocean.com/ubuntu trusty-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://mirrors.digitalocean.com/ubuntu trusty multiverse
deb-src http://mirrors.digitalocean.com/ubuntu trusty multiverse
deb http://mirrors.digitalocean.com/ubuntu trusty-updates multiverse
deb-src http://mirrors.digitalocean.com/ubuntu trusty-updates multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://mirrors.digitalocean.com/ubuntu trusty-backports main restricted universe multiverse
deb-src http://mirrors.digitalocean.com/ubuntu trusty-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu trusty partner
# deb-src http://archive.canonical.com/ubuntu trusty partner
deb http://security.ubuntu.com/ubuntu trusty-security main
deb-src http://security.ubuntu.com/ubuntu trusty-security main
deb http://security.ubuntu.com/ubuntu trusty-security universe
deb-src http://security.ubuntu.com/ubuntu trusty-security universe
K.Marek
  • 71
  1. Comment that http://httpredir.debian.org/debian/ repository to disable it
  2. Update package list
    sudo apt-get update
  3. Force remove libc-l10n
    sudo dpkg remove libc-l10n
  4. Check for packages names and available versions
    apt-cache policy libc6* locales
  5. Downgrade the installed libc packages
    sudo apt-get install libc-bin=2.19-0ubuntu6.9 libc6-dev=2.19-0ubuntu6.9 libc6-i386=2.19-0ubuntu6.9 locales=2.19-0ubuntu6.9
    I'm not sure about which the complete list but if you get a problem, update the question with the output of apt-cache policy libc6* locales
  6. Check if we miss anything
    sudo apt-get -f install
user.dz
  • 49,176
