I had this working on Elementary but then it stopped so I switched to Ubuntu and I still can not get this driver installed and working.
I followed this tutorial https://community.linuxmint.com/tutorial/view/1796
As well as using the same install file but sudo bash install. I keep getting this error and output:
make -C /lib/modules/`uname -r`/build M=/home/alyson/Downloads/MT7630E-release/rt2x00 modules
make[1]: Entering directory '/usr/src/linux-headers-4.4.0-28-generic'
  Building modules, stage 2.
  MODPOST 1 modules
make[1]: Leaving directory '/usr/src/linux-headers-4.4.0-28-generic'
make -C /lib/modules/`uname -r`/build M=/home/alyson/Downloads/MT7630E-release/btloader modules
  MODPOST 1 modules
cp -v firmware/*/* /lib/firmware/
'firmware/BT/mt76x0.bin' -> '/lib/firmware/mt76x0.bin'
'firmware/Wi-FI/MT7650E234.bin' -> '/lib/firmware/MT7650E234.bin'
cp rt2x00/mt7630e.ko /lib/modules/`uname -r`/kernel/drivers/net/wireless/
cp btloader/mt76xx.ko /lib/modules/`uname -r`/kernel/drivers/net/wireless/
depmod
modprobe: ERROR: could not insert 'mt7630e': Required key not available
I am assuming this is a 16.04 issue, but I do not know enough to work around it or know how to find another driver. any help would be greatly appreciated ! :)
anand mbs
  • 431
This driver (on GitHub) works pretty well for me:
Installation
You need kernel headers to build the driver
As an example, on Debian and derivatives, assuming you're on an amd64 system:
sudo apt install build-essential linux-headers-amd64
That's all for dependencies.
First give some file execution permission:
chmod u+x install test uninstall bpatch
Now to install it, run:
./install
To test it without installing, run:
./test
To uninstall, run:
./uninstall
To install with dkms:
sudo make dkms
The driver will automatically load at startup.
Zanna
  • 72,312
jics
  • 182
  • 13
