I've been setting up a new install of Ubuntu on a Raspberry Pi 3. I started with the image from here, updated and upgraded all packages, upgraded the distro, and upgraded the rPi firmware.
All was going well, but at some point along this path I completely lost my networking. It's hard to say when because I did multiple steps before rebooting.
Since other weird things were happening (booting would sometimes work, sometimes not) I decided to re-pave taking detailed notes of my installation steps along the way. Here they are:
- write base image to SD card
- boot
- change password when instructed during login
- install rpi-update:
sudo curl -L --output /usr/bin/rpi-update https://raw.githubusercontent.com/Hexxeh/rpi-update/master/rpi-update && sudo chmod +x /usr/bin/rpi-update- noticed a message "unable to resolve host ubuntu" so added
127.0.0.1 ubuntuto my /etc/hosts file
- reboot (just to be sure networking is still up)
- run
rpi-update:sudo apt-get install binutilssudo rpi-update
- reboot to activate new firmware (and confirm that networking still works)
sudo apt-get updatesudo apt-get upgrade(85 packages upgraded, around 65MB download)- reboot
At this point networking no longer works. I noticed these errors in the boot output (taken from /var/log/syslog):
Jul 14 01:18:34 ubuntu systemd[1]: Starting LXD - container startup/shutdown...
Jul 14 01:18:34 ubuntu lxd[18312]: error: open /var/lib/lxd/containers: no such file or directory
Jul 14 01:18:34 ubuntu systemd[1]: lxd-containers.service: Main process exited, code=exited, status=1/FAILURE
Jul 14 01:18:34 ubuntu systemd[1]: Failed to start LXD - container startup/shutdown.
Jul 14 01:18:34 ubuntu systemd[1]: lxd-containers.service: Unit entered failed state.
Jul 14 01:18:34 ubuntu systemd[1]: lxd-containers.service: Failed with result 'exit-code'.
Jul 14 01:19:24 ubuntu systemd[1]: Starting Raise network interfaces...
Jul 14 01:19:24 ubuntu dhclient[887]: Internet Systems Consortium DHCP Client 4.3.3
Jul 14 01:19:24 ubuntu ifup[822]: Internet Systems Consortium DHCP Client 4.3.3
Jul 14 01:19:24 ubuntu ifup[822]: Copyright 2004-2015 Internet Systems Consortium.
Jul 14 01:19:24 ubuntu ifup[822]: All rights reserved.
Jul 14 01:19:24 ubuntu ifup[822]: For info, please visit https://www.isc.org/software/dhcp/
Jul 14 01:19:24 ubuntu dhclient[887]: Copyright 2004-2015 Internet Systems Consortium.
Jul 14 01:19:24 ubuntu dhclient[887]: All rights reserved.
Jul 14 01:19:24 ubuntu dhclient[887]: For info, please visit https://www.isc.org/software/dhcp/
Jul 14 01:19:24 ubuntu ifup[822]: Cannot find device "eth0"
Jul 14 01:19:24 ubuntu dhclient[887]: Error getting hardware address for "eth0": No such device
Jul 14 01:19:24 ubuntu ifup[822]: Error getting hardware address for "eth0": No such device
Jul 14 01:19:24 ubuntu ifup[822]: If you think you have received this message due to a bug rather
Jul 14 01:19:24 ubuntu ifup[822]: than a configuration issue please read the section on submitting
Jul 14 01:19:24 ubuntu ifup[822]: bugs on either our web page at www.isc.org or in the README file
Jul 14 01:19:24 ubuntu ifup[822]: before submitting a bug. These pages explain the proper
Jul 14 01:19:24 ubuntu ifup[822]: process and the information we find helpful for debugging..
Jul 14 01:19:24 ubuntu ifup[822]: exiting.
Jul 14 01:19:24 ubuntu ifup[822]: Failed to bring up eth0.
Jul 14 01:19:24 ubuntu dhclient[887]: If you think you have received this message due to a bug rather
Jul 14 01:19:24 ubuntu dhclient[887]: than a configuration issue please read the section on submitting
Jul 14 01:19:24 ubuntu dhclient[887]: bugs on either our web page at www.isc.org or in the README file
Jul 14 01:19:24 ubuntu dhclient[887]: before submitting a bug. These pages explain the proper
Jul 14 01:19:24 ubuntu dhclient[887]: process and the information we find helpful for debugging..
Jul 14 01:19:24 ubuntu dhclient[887]: exiting.
Jul 14 01:19:24 ubuntu systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
Jul 14 01:19:24 ubuntu systemd[1]: Failed to start Raise network interfaces.
Jul 14 01:19:24 ubuntu systemd[1]: Dependency failed for Initial cloud-init job (metadata service crawler).
Jul 14 01:19:24 ubuntu systemd[1]: cloud-init.service: Job cloud-init.service/start failed with result 'dependency'.
Jul 14 01:19:24 ubuntu systemd[1]: networking.service: Unit entered failed state.
Jul 14 01:19:24 ubuntu systemd[1]: networking.service: Failed with result 'exit-code'.
I also now have instability during boot. Sometimes it works, sometimes I get an exception trace with a final message of:
Fixing recursive fault but reboot is needed!
I've seen this and running sudo service lxd restart did fix the LXD issue (after a very long delay), but the networking issue remains.
I've also seen this, which seemed like my exact issue until I tried bringing the misnamed ethernet network up:
ifconfig enxb827eb0ecff3 up
SIOCSIFFLAGS: Operation not permitted
sudo ifconfig enxb827eb0ecff3 up
(no output)
sudo ip link set enxb827eb0ecff3 name eth0
RTNETLINK answers: Device or resource busy
So at this point I'm well and truly out of my depth when it comes to Linux trouble-shooting. Can anyone tell me how to revive networking on my system? And perhaps why this happens in the first place on a fresh install?
Output of ifconfig:
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1600 errors:0 dropped:0 overruns:0 frame:0
TX packets:1600 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1
RX bytes:118400 (118.4 KB) TX bytes:118400 (118.4 KB)
Output of ifconfig -a:
enxb827eb0ecff3 Link encap:Ethernet HWaddr b8:27:eb:0e:cf:f3
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
wlan0 Link encap:Ethernet HWaddr b8:27:eb:5b:9a:a6
Output of networkctl:
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback n/a n/a
2 sit0 sit n/a n/a
3 enxb827eb0ecff3 ether n/a n/a
4 wlan0 wlan n/a n/a
4 links listed.
