I am trying to install Grunt v1.0.0 in Ubuntu using this command
sudo npm -g install grunt
or
sudo npm -g install grunt@1.0.0
in both cases, I am getting
/usr/local/bin/grunt ->/usr/local/lib/node_modules/grunt/bin/grunt/usr/local/lib`-- grunt@1.0.1
I have installed Node.js version : 4.2 and Npm.
output of npm list -g
    /usr/local/lib
`-- grunt-cli@1.2.0
  +-- findup-sync@0.3.0
  | `-- glob@5.0.15
  |   +-- inflight@1.0.5
  |   | `-- wrappy@1.0.2
  |   +-- inherits@2.0.1
  |   +-- minimatch@3.0.2
  |   | `-- brace-expansion@1.1.5
  |   |   +-- balanced-match@0.4.1
  |   |   `-- concat-map@0.0.1
  |   +-- once@1.3.3
  |   `-- path-is-absolute@1.0.0
  +-- grunt-known-options@1.1.0
  +-- nopt@3.0.6
  | `-- abbrev@1.0.9
  `-- resolve@1.1.7
When I am hitting terminal with user@super:~$grunt
I am getting command not found response.
what wrong I am doing?
Thanks
Prakash P
  • 319
It looks like you installed Grunt globally via NPM, but did not install Grunt CLI, which puts the 'grunt' command in your system path. Try this:
npm install -g grunt-cli
See the documentation here: https://gruntjs.com/getting-started#installing-the-cli
