42
The recipies for changing one's login screen in 14.04 [EDIT or in 15.04, 15.10] don't work in 16.04. The "custom" background shows for a split second and then fades to the Ubuntu one. So, how do I change the login screen background in 16.04?
[Edit: this post is not a duplicate because all other related questions specifically refer to previous versions of Ubuntu, and the solutions to those do not apply here (as they do not work on 16.04).]
Greg Kramida
  • 1,080
7 Answers7
34
The greeter by default load the selected user background if it is available. A fade transition used to change between backgrounds of users including greeter default (for guest user). I think that the question should: How to stop lightdm greeter from loading the user background?
Be aware of two distinct greeters, default is unity-greeter. I noticed that some answer here in AU, don't mention this and mix up between them.
Using lightdm-gtk-greeter
GUI tool
  1. Install the settings tool
    sudo apt install lightdm-gtk-greeter-settings
  2. Run it
    pkexec lightdm-gtk-greeter-settings
  3. In Appearance tab: Select the image
  4. On same tab: Unckeck User user wallpaper if available
  5. Save & Close
CLI tools
  1. Open lightdm greeter settings file
    sudo nano /etc/lightdm/lightdm-gtk-greeter.conf
  2. Change it this way
    [greeter]
    background = /usr/share/backgrounds/Spring_by_Peter_Apas.jpg
    user-background = false
  3. Ctrl+o to save it then Ctrl+x to exit.
Using unity-greeter (default)
Same answer by Serg, I have tested it in a fresh VBox Ubuntu 16.04.
  • Change the background of the login screen
    $ sudo nano /usr/share/glib-2.0/schemas/10_unity_greeter_background.gschema.override
    [com.canonical.unity-greeter]
    draw-user-backgrounds=false
    background='/usr/share/backgrounds/Spring_by_Peter_Apas.jpg'
    $ sudo glib-compile-schemas /usr/share/glib-2.0/schemas
    $ sudo service lightdm restart
  • Some debug hints:
    1. Purge lightdm-gtk-greeter settings
      sudo apt purge lightdm-gtk-greeter lightdm-gtk-greeter-settings
      Or you may want just disabling it temporary
      sudo mv /usr/share/lightdm/lightdm.conf.d/60-lightdm-gtk-greeter.conf /usr/share/lightdm/lightdm.conf.d/60-lightdm-gtk-greeter.conf.disabled
      To enable it back
      sudo mv /usr/share/lightdm/lightdm.conf.d/60-lightdm-gtk-greeter.conf.disabled /usr/share/lightdm/lightdm.conf.d/60-lightdm-gtk-greeter.conf
      Restarting the lightdm is needed
      sudo systemctl restart lightdm
    2. Reinstall unity-greeter to remove any change in /usr/share/glib-2.0/schemas/com.canonical.unity-greeter.gschema.xml
      sudo apt install --reinstall unity-greeter
    3. Check if there any other dconf override file that take priority
      grep -rn -e "com.canonical.unity-greeter" -e "background=" -e "draw-user-backgrounds=" /usr/share/glib-2.0/schemas/
user.dz
  • 49,176
To change the login screen in Ubuntu 16.04 I used the following:
gksu gedit /usr/share/glib-2.0/schemas/10_unity_greeter_background.gschema.override
Insert these lines:
background='/home/$USER/Pictures/1920x1080-TuxSuckingWindowsTetraWwallpaper.jpg'
# After changing use: sudo glib-compile-schemas /usr/share/glib-2.0/schemas
Where:
  • $USER = your user ID.
  • Pictures = your wallpaper directory.
  • 1920x1080-TuxSuckingWindowsTetraWwallpaper.jpg = your image file name (can be .png format too).
  • # (comment) ... reminds you what to do after changing!
Save the file and exit gedit
Now compile the new login wallpaper with:
Last step is to reboot.
Many thanks and credit to Serg: (Change the background of the login screen) Note on my system this no only changes the initial login screen but also the lock screen login as well.
Point and click with Nautilus to set login screen wallpaper
I wrote a script where you can navigate to a directory / image, right click on it and set it as login screen / lock screen background using Nautilus (file manager now called "Files"): Nautilus can set desktop wallpaper. How can it set login and lock screen wallpaper?
Nautilus set-login-wallpaper Drop Down
Run sudo lightdm-gtk-greeter-settings (if installed). Go to the Appearance tab, and select Background > Image.
Note: If you're selecting an image from your home folder and the folder's encrypted, it won't work, because /home/user hasn't been mounted yet.
This worked well for me on 16.04 LTS and without installing extra-software https://www.linuxslaves.com/2016/06/easiest-way-change-ubuntu-login-screen-background.html
In short: Open sudo gedit /usr/share/gnome-background-properties/xenial-wallpapers.xml and add your background image to the list. Then open the "Change background image" by right-clicking on your desktop, select the image and it's done for both working and login screen. Eventually restart to try it out.
Ste
To set the unity greeter as default, in Ubuntu 16.04 login screen, edit the file
and change the "greeter-session" line to "greeter-session=unity-greeter"
Sunny127
  • 1,305
Duo Step-
  1. sudo cp Downloads/human_ubuntu-wallpaper-1366x768.jpg /usr/share/backgrounds/
  2. sudo mv /usr/share/backgrounds/human_ubuntu-wallpaper-1366x768.jpg /usr/share/backgrounds/warty-final-ubuntu.png
Just lock and comment!
As @OrganicMarble said, Ubuntu Tweak should do the trick. I installed it and in the Tweaks tab there is a tab called 'Login settings'. Unlock the page in the top right by entering the password and you can change the settings wallpaper. Since then my login and lock screens were changed.
