when I install Ubuntu with a USB-disk, following message occurred:
task swapper/0:1 blocked for more than 120 seconds.
And my computer have an CPU of core-i7-4710MQ and 12 GB memory.
But, if I install Ubuntu on a very old computer, I can success.It is a double core Intel CPU with a 2 GB memory.
The SSD I used on both computer is the same one. After I installed Ubuntu on that old computer with my SSD, I replace the hard disk of my computer with that SSD witch installed Ubuntu 16.04 successful already, it can't run.
My bios is legacy at first. When I change to UEFI mode, I can enterenter image description here . But, no matter what I choose, my screen becomes to be grey, and a cursor twinlkling. about 2 or 3 minutes later, following message occurred:
What I should do? or what information I should provide? thanks!
You can install Ubuntu 16.04 using a compact disk as follows:
  1. Power on your laptop/pc
  2. Insert the CD
  3. Restart laptop/pc
  4. Press F2 or F12 continuously
  5. Select legacy support priority first
  6. Press F10
  7. Wait sometime
  8. Now select language & press continue
  9. Now select connect internet connection if any & press continue
  10. Select installation method & press continue
  11. Select region & press continue
  12. Fill all requirements & press install now
  13. Wait for installation
  14. Restart laptop/pc & remove CD
  15. Open terminal & run sudo apt-get update
  16. Now enjoy with ubuntu 16.04 LTS
amc
  • 7,292
