Here's the error messsage :
  • Hostname was NOT found in DNS cache
  • Resolving timed out after 15528 milliseconds
  • Closing connection 1
  • Resolving timed out after 15529 milliseconds
  • Closing connection 2
and loop more..
How do i solve this issue?
One of these options can solve the problem.
  1. Close Uget and Delete .config/uGet folder. then open uget and see the problem solved.
  2. using aria2 instead of curl. go to the uGet settings edit>settings>plug-in and change plug-in matching order to the aria2 or aria2+curl
If you don't have aria2:
sudo apt-get install aria2
ICE
  • 2,075
