We repeatedly see that when an apache2 update arrives and is installed it causes the libapache2-mod-php5 package to be removed and does not subsequently re-install it automatically.
We must subsequently re-install the libapache2-mod-php5 manually in order to restore functionality to our web server.
Please see the following github gist, it is a contiguous section of our server's dpkg.log showing the November 14, 2011 update to apache2:
https://gist.github.com/1368361
it includes
2011-11-14 11:22:18 remove libapache2-mod-php5 5.3.2-1ubuntu4.10 5.3.2-1ubuntu4.10
Is this a known issue? Do other people see this too? I could not find any launchpad bug reports about it.
Platform details:
$ lsb_release -ds
Ubuntu 10.04.3 LTS
$ uname -srvm
Linux 2.6.38-12-virtual #51~lucid1-Ubuntu SMP Thu Sep 29 20:27:50 UTC 2011 x86_64
$ dpkg -l | awk  '/ii.*apache/ {print $2 " " $3 }'
apache2 2.2.14-5ubuntu8.7
apache2-mpm-prefork 2.2.14-5ubuntu8.7
apache2-utils 2.2.14-5ubuntu8.7
apache2.2-bin 2.2.14-5ubuntu8.7
apache2.2-common 2.2.14-5ubuntu8.7
libapache2-mod-authnz-external 3.2.4-2+squeeze1build0.10.04.1
Thanks
At a high-level the update process looks like:
package package_name do
        action :upgrade
        case node[:platform]
        when 'centos', 'redhat', 'scientific'
                options '--disableplugin=fastestmirror'
        when 'ubuntu'
                options '-o Dpkg::Options::="--force-confdef" -o Dpkg::Options::="--force-confold"'
        end
end
But at a lower level
        def install_package(name, version)
          run_command_with_systems_locale(
            :command => "apt-get -q -y#{expand_options(@new_resource.options)} install #{name}=#{version}",
            :environment => {
              "DEBIAN_FRONTEND" => "noninteractive"
        end
        def upgrade_package(name, version)
        end
So Chef is using "install" to do "update".
This sort of moves the question around to "how does apt-get safe-upgrade" remember to re-install libapache-mod-php5?
The exact sequence of packages that triggered this was:
apache2
apache2-mpm-prefork
apache2-mpm-worker
apache2-utils
apache2.2-bin
apache2.2-common
But the code is attempting to run checks to make sure the packages in that list are installed already before attempting to "upgrade" them.
when 'debian', 'centos', 'fedora', 'redhat', 'scientific', 'ubuntu'
        # first primitive way is to define the updates in the recipe
        # data bags will be used later
        %w/
               apache2
               apache2-mpm-prefork
               apache2-mpm-worker
               apache2-utils
               apache2.2-bin
               apache2.2-common
        /.each{ |package_name|
                Chef::Log.debug("is #{package_name} among local packages available for changes?")
                next unless node[:packages][:changes].keys.include?(package_name)
                Chef::Log.debug("is #{package_name} available for upgrade?")
                next unless node[:packages][:changes][package_name][:action] == 'upgrade'
                        action :upgrade
                        when 'ubuntu'
                        end
                end
                tag('upgraded')
        # after upgrading everything, run yum cache updater
        if tagged?('upgraded')
                # Remove old orphaned dependencies and kernel images and kernel headers etc.
                # Remove cached deb files.
                when 'ubuntu'
                        execute 'apt-get -y autoremove'
                        execute 'apt-get clean'
                # Re-check what updates are available soon.
                when 'centos', 'fedora', 'redhat', 'scientific'
                        node[:packages][:last_time_we_looked_at_yum] = 0
                end
                untag('upgraded')
        end
end
But it's clear that it fails since the dpkg.log has
2011-11-14 11:22:25 install apache2-mpm-worker  2.2.14-5ubuntu8.7
on a system which does not currently have apache2-mpm-worker. I will have to discuss this with the author, thanks again.
It's probably that you are running the mpm-worker version of apache2, which does not like libapache2-mod-php5.
dpkg -l | grep apache2-mpm
You may wish to use apache2-mpm-prefork instead, which works better with mod_php5
Marco Ceppi
  • 48,827
delimiter
  • 185
