I have literally just installed Kubuntu to see what it is all about. I am a total newbie and have tried to install a programme called uGet.
I managed to download it but don't know where to go from there. I have been reading the forums and have tried Discover, but uGet is not available there so have tried a few things in bash, but no luck (please see below). Any help greatly appreciated.
nleric@nleric-SATELLITE-L50-C:~$ sudo apt-get install synaptic
[sudo] password for nleric:
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Reading package lists... Done
Building dependency tree
Package synaptic is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or is only available from another source
E: Package 'synaptic' has no installation candidate
nleric@nleric-SATELLITE-L50-C:~$ sudo apt-get install uGet
E: Unable to locate package uGet
nleric@nleric-SATELLITE-L50-C:~$ sudo apt-get install software-center
Package software-center is not available, but is referred to by another package.
E: Package 'software-center' has no installation candidate
TheWanderer
  • 19,525
  • 52
  • 65
uGet actually has instructions on its website.
You need to run the commands below to add the PPA, then install it.
sudo add-apt-repository ppa:plushuang-tw/uget-stable
sudo apt update
sudo apt install uget
Just a pointer, I don't think I've ever seen a package name with uppercase letters, so when you install a package through the terminal, use lowercase. I also think package names are case-sensitive, but I'm not sure about that.
If you want the Ubuntu Software Center, you need to run one of the following commands.
If you have Ubuntu 15.10 or lower, run:
As you are getting an error when trying to install this, I'm assuming you have 16.04
16.04 (and above):
sudo apt-get install gnome-software packagekit
TheWanderer
  • 19,525
  • 52
  • 65
At least Synaptics is part of the universe package as far as I know.
So you need to activate universe:
sudo add-apt-repository universe
sudo apt-get update
I hope this works too on Kubuntu
