I am using Ubuntu 16.04, I have succesfully installed matlab 2010b without any error. The same sofware had worked with Ubuntu 14.04, but with 16.04 it says:
error while loading shared libraries: libXp.so.6: cannot open shared object file: No such file or directory
I also tried yum and apt-get to install libxp.so.6 but it shoewd errors, which I have attached with screenshots.
Error while lanching the matlab c Error while installing libxp.so.6 using yum
Running yum repolist all tells "0" , which means there are no repositories, please help to add required repository to install libxp.s0.6
That file is not available anymore on Xenial and other Ubuntu versions more recent than Trusty (also in Wily is not present).
Since Matlab is a proprietary software you should report the error to their developers, so that they can update the package and make it compatible with the new versions of Ubuntu and Debian.
In the meanwhile you can probably manually install an old version for Trusty, but probably it will also break other packages and dependencies in your system.
EDIT: The Matlab version that you are using is 2010b, so many things have changes since then. I strongly suggest that you use a recent version of the program (maybe 2016a, since we are here), in order to maintain compatibility with the systems you are using. In details, that version R2010b supports officially only Ubuntu 9.10 and 10.04.
dadexix86
  • 6,776
-1
Try following solution
sudo vim /etc/apt/sources.list
append this line to sources list:
deb http://security.ubuntu.com/ubuntu precise-security main
Then again on terminal run following commands
sudo apt update
sudo apt install libxp6
Source: http://shengweihou.com/wordpress/?p=232
Kapil
  • 509
