When I first set my computer up with LUKS encryption, during boot, right after Grub2, Plymouth takes over and you get a nice graphical screen with the prompt to enter the passphrase. And that screens remain until the Ubuntu desktop opens.
Once I installed the NVIDIA driver for my video card, that graphical screen is gone, and right after Grub2, there is a text screen for passphrase entry, then once decryption takes place, the NVIDIA logo comes up. And on shutdown/restart, it also dumps into a text screen.
I've seen some solutions on fixing Plymouth after an NVIDIA driver is installed, but not sure if that works with LUKS encryption, and I don't want to risk screwing things up and not being able to decrypt the partition.
This is for Xubuntu 14.04.4
jub
  • 141
This worked: How to fix plymouth (splash screen) in all Ubuntu releases!
The mistake I made when I first tried it is not using the correct resolution. I used the native resolution of my monitor, 1600x1200. But apparently Grub and Plymouth can have a different max resolution than the monitor and video card.
Since hwinfo is not available on Ubuntu 14.04, I booted into Grub2, dropped to command line and ran vbeinfo. Max resolution listed was 1280x800x32.
So with that info, the solution is:
sudo apt-get install v86d
sudo gedit /etc/default/grub
Find this line:
#GRUB_GFXMODE=640x480
leave commented out and add:
GRUB_GFXMODE=1280x800x32 (use max resolution found using vbeinfo)
GRUB_GFXPAYLOAD_LINUX=keep
Save file, then in terminal:
echo FRAMEBUFFER=y | sudo tee /etc/initramfs-tools/conf.d/splash
sudo update-initramfs -u
sudo update-grub
This gave me the 'correct' looking resolution for Plymouth both at startup and shutdown. Everything looks like it did before installing the nvidia driver, apart from a brief flash of the nvidia logo between Plymouth and the desktop launching.
I think the 'late resume failure' error report is unrelated, as I did not encounter this error report this time around.
jub
  • 141
