I have a Kingston 64gb USB flashdrive that isn't working. When I use the command lsusb I get the following: '
Bus 002 Device 021: ID 0951:1665 Kingston Technology Digital DataTraveler SE9 64GB
So it finds my Kingston flasdrive. Searching learned me that I now need to use "sudo fdisk -l". This does not show the Kingston drive. I only get:
Disk /dev/sda: 640.1 GB, 640135028736 bytes
255 heads, 63 sectors/track, 77825 cylinders, total 1250263728 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x38601c96
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 206848 552536063 276164608 7 HPFS/NTFS/exFAT
/dev/sda3 552538110 1250263039 348862465 f W95 Ext'd (LBA)
Partition 3 does not start on physical sector boundary.
/dev/sda5 552538112 1197832191 322647040 7 HPFS/NTFS/exFAT
/dev/sda6 1197834240 1201831935 1998848 82 Linux swap / Solaris
/dev/sda7 1201833984 1250263039 24214528 83 Linux
I also tried using GParted, but this program also cannot find the device. A laptop using windows can also not find the device.
What can be the problem and what steps can I take to solve the problem?
Thanks!
Kind regards Bert
