-1
I have windows 10 on my lap and i don't want to install Ubuntu in here.
I have a external hard disk and i want to install Ubuntu in this.
How to achieve dual boot with both windows on system and Ubuntu on external hard disk?
I need following criteria to be satisfied :
  • If i don't plug my external hard disk then the system should boot into windows 10.
  • If i plug in external hard disk then i should have option to select windows 10 or Ubuntu.
You can do this by configuring the boot order in your BIOS settings. You should set as primary boot device the external hard drive and as the second you should set the internal hard drive. That means that when an external hard drive(Ubuntu) is connected the system will boot of it and if not, the system will boot from the internal drive(WIndows 10)
konmal88
  • 333
