How do I make Ubuntu 12.04 to start at a runlevel other than default 2.although I could change run level after starting from terminal it does not remain when I restart
Asked
Active
Viewed 528 times
You can give the kernel your desired run-level on boot by pressing C with your boot-entry selected and add init=<your-runlevel-number> to the kernel parameter passed on boot and press F10 to boot with that edited line once.
Or you can edit your grub.cfg to edit the parameters permanent (not recommended for Ubuntu and other distributions that check for change of important configuration files).
@videonauth suggest in chat and is right about that you have to update the /etc/default/grub and the files in /etc/grub.d/ instead followed by a sudo update-grub to update your installation properly.
Videonauth
- 33,815
Kupferdrache
- 265
