rhythmbox-client --print-playing tells me the name of a song, regardless of whether it is actually playing. I simply need to know whether or not sound is currently being generated by rhythmbox (so that I know whether or not I want to pause it and later unpause it).
Update:
One ugly candidate answer:
I think rhythmbox really may be devoid of this basic interface.
But when I run pacmd list-sink-inputs which I gather queries the mixer about what is feeding, it still lists rhythmbox regardless of whether it's playing. However, it has a "state" row in the output, which is "RUNNING" or "CORKED" depending on whether the music is paused.
user.dz
  • 49,176
CPBL
  • 848
Media Player Remote Interfacing Specification (MPRIS)
You can use the MPRIS2 DBus interface, it is well established standard and implemented by almost all players.
The same standard that is used by Ubuntu Unity sound indicator to detect, show and control players. So your script will be generic and could work with any player you like.
Hint: Use D-Feet to explore it, d-feet is DBus monitor and can interact with DBus interfaces directly.
  • Pause
    gdbus call \
      --session \
      --dest org.mpris.MediaPlayer2.rhythmbox \
      --object-path /org/mpris/MediaPlayer2 \
      --method org.mpris.MediaPlayer2.Player.Pause
  • Pause/Resume
    gdbus call \
      --session \
      --method org.mpris.MediaPlayer2.Player.PlayPause
  • Check Status
    ~$ gdbus call \
         --session \
         --method org.freedesktop.DBus.Properties.Get \
             org.mpris.MediaPlayer2.Player PlaybackStatus
    (<'Playing'>,)
    ~$ gdbus call \
         --session \
    (<'Stopped'>,)
jvandoorn
user.dz
  • 49,176
pacmd list-sink-inputs gives a list of all running players, so you don't even need to know which ones you're looking for in advance, and tells you which ones are playing / paused, etc. I wrote this for Python, but you could do a better job with awk or bash, I'm sure:
import commands,re
def linux_musicplayer_check_whether_playing():
    Report which applications are currently sending
    sound to the mixer, based on the output of the command:
    Also list those which are running/connected,
    but not currently sending sound.
    Returns a dict listing applications and a boolean playing state.
    This is very GNU/Linux specific! At least, it works on Ubuntu.
    On other platforms, there may be direct ways for each application.
    For instance, under Ubuntu, you can ask banshee:
    'playing' in commands.getstatusoutput("banshee --query-current-state")[1])
    but there's nothing like this for rhythmbox.
    found={}
    for cl in commands.getstatusoutput("pacmd list-sink-inputs |grep -e index: -e state: -e client:")[1].split('index:')[1:]:
        found[ re.findall('<(.*?)>', cl.split(':')[2])[0].lower() ]  =
                     'RUNNING' in cl.split(':')[1]
    return(found)
CPBL
  • 848
