After updating Ubuntu software 16.04 I couldn't use VLC player any more and then I removed VLC and tried to install it again and this showed:
This error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
Does anyone know what should I do to repair VLC ?
Lana
Run the following commands in terminal.
Issue the following command to get a list of the held packages:
dpkg --get-selections | grep hold
Then issue the following command against each held package:
echo "package_name install" | sudo dpkg --set-selection
Now you should be able to install VLC with the following:
This makes sure your packages are up to date:
sudo apt-get update ; sudo apt-get upgrade
This removes any existing VLC install, including any configuration files:
sudo apt-get purge vlc
This installs VLC:
sudo apt-get install vlc
