I use the Breeze Dark theme on Kubuntu, which also works perfectly with GTK+2 applications, but it's not fully supported on GTK+3 applications like Firefox yet.
Because of that, I've set my system to use Breeze Dark for GTK+2 programs, and the light Breeze for GTK+3 programs.
However, the KDE settings window (GNOME Application Style) only lets me pick a single icon pack for both versions. Is it possible to use different icon sets for them? The "fallback theme" option doesn't work for that.
I don't have KDE installed right now to test. As I remember with Kubuntu 15.04, KDE was creating two files to override GTK theme settings.
GTK2:
~/.gtkrc-2.0
GTK3:
~/.config/gtk-3.0/settings.ini
As they are two separate file you can change them differently. But you may need to change them to read-only so KDE config tool will not able to change them.
I could find a reference with example: Archlinux Wiki - GTK
Basic theme configuration
To manually change the GTK+ theme, icons, font and font size, add the following to the configuration files, for example:
GTK+ 2:
~/.gtkrc-2.0
gtk-icon-theme-name = "Adwaita"
gtk-theme-name = "Adwaita"
gtk-font-name = "DejaVu Sans 11"
GTK+ 3:
$XDG_CONFIG_HOME/gtk-3.0/settings.ini
[Settings]
gtk-icon-theme-name = Adwaita
gtk-theme-name = Adwaita
gtk-font-name = DejaVu Sans 11
Note: The icon theme name is the name defined in the theme's index file, not the name of its directory.
user.dz
  • 49,176
