I am running Ubuntu 15.10 in VirtualBox 4.2.34 on a Windows 7 host.
I can't get the desktop to fit the screen.
I installed Guest Additions and allocated enough of video memory, but no dice.
You need install the virtualbox guest additions:
  • In the VM's menu: click "Devices" -> "Insert Guest Additions CD Image" (The guest additions cd image will be mount in your guest's cdrom"
  • Run
    .{path_to_your_CDROM_mount_in_the_GUEST}/VboxLinuxAddition.run
  • Restart your VM
  • Now, with the correct driver installed and loaded: "You have to select "Auto-resize guest display" on "View" menu".
Hope this help!
Before installing the guest addons as described in this answer, I noticed that on a fresh Xubuntu the kernel modules could not been buld because of missing dependencies. So I installed them first using
apt-get install -y gcc make perl
Now I could run VboxLinuxAddition.run from the mounted ISO file. After a reboot, the guest addons were installed. Auto-resize guest display worked, after disabling and re-enabling it in the View menu of the host.
Lion
  • 151
-1
Installing gcc make and perl solved my issue.
sudo apt install gcc make perl
Hope this helps someone.
Rahul
  • 405
-1
You have to select "Auto-resize guest display" on "View" menu.
If this doesn't work, then you have done something wrong at Guest Additions installation.
katsos
