13
I'm moving some files around, and I want to make sure that the mv command I've typed is correct before I go ahead and run it.
If I was using apt-get, I could use the -s flag to perform a simulation that would actually do anything.
Does mv have a similar function, that would simulate the moving of the files but not actually do anything?
Seth
  • 59,332
5 Answers5
10
Function below is for verbosely checking mv syntax. Note , that it only works for 2 arguments, SOURCE and DESTINATION, and doesn't check for -t flag.
The function is to be placed into ~/.bashrc . To use it immediately , open new terminal or run source ~/.bashrc
mv_check()
    # Function for checking syntax of mv command
    # sort of verbose dry run
    # NOTE !!! this doesn't support the -t flag
    # maybe it will in future (?)
    # check number of arguments
    if [ $# -ne 2   ]; then
        echo "<<< ERROR: must have 2 arguments , but $# given "
        return 1
    fi
    # check if source item exist
    if ! readlink -e "$1" > /dev/null
    then
        echo "<<< ERROR: " "$item" " doesn't exist"
        return 1
    fi
    # check where file goes
    if [ -d "$2"  ]
    then
        echo "Moving " "$1" " into " "$2" " directory"
    else
        echo "Renaming "  "$1" " to " "$2"
    fi
Here's some test runs:
$> mv_check  TEST_FILE1  bin/python
Moving  TEST_FILE1  into  bin/python  directory
$> mv_check  TEST_FILE1  TEST_FILE2
Renaming  TEST_FILE1  to  TEST_FILE2
$> mv_check  TEST_FILE1  TEST_FILE 2
<<< ERROR: must have 2 arguments , but 3 given
$> mv_check  TEST_FILE1  TEST_FILE\ 2
Renaming  TEST_FILE1  to  TEST_FILE 2
$> mv_check  TEST_FILE1  "TEST_FILE 2"
<<< ERROR: must have 2 arguments , but 1 given
There is a programm on github called maybe which may be what you are looking for.
According to their project description, maybe
... allows you to run a command and see what it does to your files without actually doing it! After reviewing the operations listed, you can then decide whether you really want these things to happen or not.
So it will also show you what other programs will do to your files, not only mv.
maybe needs Python to run, but that should not be a problem. It is easy to install or build it using Python's package manager pip.
The installation process and the usage of the program are both described on the project's homepage. Unfortunatly I have no access to a Linux System at the moment, so I can not provide you with any examples on the program's usage.
maddin45
  • 171
This script should do the trick. It can handle multiple source files/directories, too. Use it the same way you would use mv - mvsim source... dest. Note that it does not pay attention to options, nor does it filter them out (it just treats them as filenames) and it might not work well with symlinks.
#!/bin/bash
if [ $# -lt 2 ]; then
    echo "Too few arguments given; at least 2 arguments are needed."
    exit 1
fi
lastArg="${@:$#}"
i=1
for param in "$@"; do
    if [ ! -e "$param" -a $i -lt $# ]; then
        echo "Error: $param does not exist."
        exit 1
    elif [ "$param" = "$lastArg" -a $i -lt $# ]; then
        echo "Error: $param is the same file/directory as the destination."
        exit 1
    fi
    ((i++))
done
if [ $# -eq 2 ]; then # special case for 2 arguments to make output look better
    if [ -d "$1" ]; then
        if [ -d "$2" ]; then
            echo "Moves directory $1 (and anything inside it) into directory $2"
            exit 0
        elif [ ! -e "$2" ]; then
            echo "Renames directory $1 to $2"
            exit 0
        else
            echo "Error: $2 is not a directory; mv cannot overwrite a non-directory with a directory."
            exit 1
        fi
    else
            echo "Moves file $1 into directory $2"
        elif [ -e "$2" ]; then
            echo "Renames file $1 to $2, replacing file $2"
        else
            echo "Renames file $1 to $2"
        fi
        exit 0
    fi
elif [ ! -e "$lastArg" ]; then
    echo "Error: $lastArg does not exist."
    exit 1
elif [ ! -d "$lastArg" ]; then
    echo "Error: $lastArg is not a directory; mv cannot merge multiple files into one."
    exit 1
fi
argsLeft=$#
echo "Moves..."
    if [ $argsLeft -eq 1 ]; then
        echo "...Into the directory $param" # has to be a directory because -f $lastArg was dealt with earlier
        exit 0
    fi
    if [ -d "$param" ]; then
            echo "Error: $lastArg is not a directory; mv cannot overwrite a non-directory with a directory."
            exit 1
        fi
        if [ $argsLeft -eq $# ]; then
            echo "The directory ${param} (and anything inside it)..."
        else
            echo "And the directory ${param} (and anything inside it)..."
        fi
    else
            echo "The file ${param}..."
        else
            echo "And the file ${param}..."
        fi
    fi
    ((argsLeft--))
done
Some examples:
$ ls
dir1  dir2  file1  file2  file3  mvsim
$ ./mvsim file1 file2
Renames file file1 to file2, replacing file file2
$ ./mvsim file1 newfile
Renames file file1 to newfile
$ ./mvsim file1 dir1
Moves file file1 into the directory dir1
$ ./mvsim file1 file2 file3 dir1
Moves...
The file file1...
And the file file2...
And the file file3...
...Into the directory dir1
$ ./mvsim file1 file2 dir1 dir2
Moves...
The file file1...
And the directory dir1 (and anything inside it)...
...Into the directory dir2
$ ./mvsim file1 file2 file3 # error - file3 isn't a directory
Error: file3 is not a directory; mv cannot merge multiple files into one.
$ ./mvsim -f -i file1 dir1 # options aren't parsed or filtered out
Error: -f does not exist.
You can ether use a more complex command like rsync to get all the desired option; that's what I recommend.
A simple way to test all your move commands use echo before the command and it will print the shell expanded mv command.
For instance I have a list of files list.txt I want to move to the current working directory. The command below does this jobs even for file names including special characters or spaces.
cat list.txt |tr '\n' '\0' | xargs -I {} -0 echo mv {} .
You will get a list of expanded move commands. Afterwards you can delete the echo in front of the mv command and run
cat list.txt |tr '\n' '\0' | xargs -I {} -0 mv {} .
abu_bua
  • 11,313
Create an executable file safemv with contents:
#!/bin/bash
Allows invocation with dryrun=1 and also protects from fraud attempts.
[ -n "$dryrun" ] && dryrun=echo
$dryrun mv "$@"
To test the substituted arguments run this file with dryrun=1, e.g.:
dryrun=1 ./safemv *.png /tmp/pngs
For actual use run this file without specifying dryrun:
This approach may be used with any potentially dangerous commands.
marabu
