I have moved from win 10 to Ubuntu 16.04. I've tried following this article and this video, but still run into problems as the latest kernel version is 4.6.3.
I'm still running on the kernel that came installed with Ubuntu which is 4.4.0.
Long story short, my keyboard, touch pad, touch screen, volume and power buttons, the stylus, wifi indicator (top right corner) and camera are not working.
I've managed to get the Wifi and Bluetooth working.
Can anyone help me out with writing/finding some patches and re-compiling the kernel?
Please post all updates and issues on My GitHub organization and any contribution is appreciated
deriver-config and Modules
To get the type cover working run SP4-1 script from deriver-config
Zanna
  • 72,312
Amir
  • 143
6 Answers6
I have a fairly nice Surface Pro 4 kernel running on my Ubuntu installation.
The Rundown
What works:
  • wifi/bluetooth
  • multi-touch
  • pen
  • trackpad on the typing cover
What works somewhat:
  • hibernate - after resume there is no touch or pen
What doesn't:
  • suspend (see the note on power saving below)
  • freeze (the more battery draining version of suspend/sleep that doesn't reliably work)
  • the typing cover
What I haven't tried:
  • the cameras
General idea
The general idea behind this kernel is to take the changes done by Hyungwoo Yang at https://github.com/ipts-linux-org/ipts-linux-new/wiki and apply them to the Ubuntu 4.9rc3 kernel. Here are the steps to get the kernel in order. The compilation process takes about 45 minutes using all the cores of the Surface 4. Cloning the kernel repositories requires about 1.5 gigs of disk space.
Steps to produce the kernel
  1. install Ubuntu 16.10 yakkety. to accomplish this you will need a USB hub that can handle both the ubuntu live-USB and the keyboard/mouse.
  2. boot linux with a USB keyboard.
  3. prepare the Ubuntu 4.9rc3 kernel.
    • clone the Ubuntu 4.9rc3 kernel (requires ~1.5gig of space):
      git clone git://git.launchpad.net/~ubuntu-kernel-test/ubuntu/+source/linux/+git/mainline-crack v4.9-rc3
    • download 6 patches: Patch1 Patch2 Patch3 Patch4 Patch5 Patch6
    • apply the patches to the kernel in order: do
      git am /path/to/THEPATCH.patch
      for each of the patches.
  4. create a patch with touch/pen support from the ipts-linux-new kernel.
    • clone the kernel (requires ~1.5gig of space) in another directory:
      git clone https://github.com/ipts-linux-org/ipts-linux-new.git
    • create the patch:
      git diff 0c183d92b20b5c84ca655b45ef57b3318b83eb9e > /path/to/ipts-linux-new_patch.txt
  5. apply the ipts-linux-new patch to v4.9rc3
    `cd /path/to/v4.9rc3`
    `patch -p1 < /path/to/ipts-linux-new_patch.txt`
    `git add .`
    `git commit -m 'Patch for Surface Pro 4 taken from ipts-linux-new.'`
  6. compile the kernel and make ubuntu .deb packages (copied from Ubuntu Kernel Compilation)
    cd /path/to/v4.9rc3
    • initialize the debian files:
      fakeroot debian/rules clean
    • configure the kernel you will build:
      fakeroot debian/rules editconfigs
      • Say yes only to the amd64 question. This will show the "menuconfig" curses interface. activate the following two options:
        • Device Drivers -> NVM express lock device (y)
        • Device Drivers -> Misc devices -> Intel Precise Touch & Stylus (m)
    • comment or remove "do_zfs = true" in "/path/to/v4.9rc3/debian.master/rules.d/amd64.mk"
    • rename the kernel by editing "/path/to/v4.9rc3/debian.master/changelog"
  7. compile the kernel (use more threads than processors to make it faster)
    `fakeroot debian/rules clean` #necessary, but I don't know why
    `DEB_BUILD_OPTIONS=parallel=5 fakeroot debian/rules binary-headers binary-generic binary-perarch`
  8. four new .debs should be created in the directory next to v4.9rc3. Install the .debs with the following command:
    `sudo dpkg -i linux-image-* linux-headers-4.9.0-040900rc3*`
  9. copy driver files from windows to linux:
    • copy driver files from "\Windows\INF\PreciseTouch\Intel" to the linux directory "/lib/firmware/intel/ipts". There should be at least 4 files with names similar to these:
      • iaPreciseTouchDescriptor.bin
      • SurfaceTouchServicingSFTConfigMSHW0078.bin
      • SurfaceTouchServicingDescriptorMSHW0078.bin
      • SurfaceTouchServicingKernelSKLMSHW0078.bin
    • Make symbolic links to these files:
      cd /lib/firmware/intel/ipts
      ln -s iaPreciseTouchDescriptor.bin intel_desc.bin
      ln -s SurfaceTouchServicingSFTConfigMSHW0078.bin config.bin
      ln -s SurfaceTouchServicingDescriptorMSHW0078.bin vendor_desc.bin
      ln -s SurfaceTouchServicingKernelSKLMSHW0078.bin vendor_kernel.bin
You should be able to boot the new kernel now. If the links are in the right place then touch and pen will work nicely.
Note on power saving
The missing suspend functionality is a major drawback. This is a due to the Microsoft "connected standby" fiasco: https://lwn.net/Articles/580451/. Freeze uses more battery (drains the battery maybe half as fast as if you had left the computer on), and doesn't seem to be reliable. With hibernate the state is successfully kept, but unfortunately, the touch and stylus functionalities do not work after resume.
I used this guide on Reddit
Had issues with fridgecow's kernel freezing up and could never restart or shut down properly, would just freeze with Ubuntu logo doing nothing.
I used cantenna's (6a and 7a) and works fine other than doesn't wake from sleep and volume buttons don't work.
Download this file (the patched kernel)
cd to the directory where it went (eg cd Downloads) and install the packages
sudo dpkg -i './linux-headers-4.4.0-rc8touchkernel+_1_amd64.deb'
sudo dpkg -i './linux-image-4.4.0-rc8touchkernel+_1_amd64.deb'
Mount your Windows partition (you can download the files from here if you deleted your Windows partition or can't find them) and copy the files to your Ubuntu root directory (you may need to adjust the path depending on the mountpoint of your Windows partition:
sudo mkdir /itouch
cp /media/$USER/Windows/Windows/INF/PreciseTouch/Intel/* /itouch
Now make symlinks to the files so that the driver can find them
sudo ln -sf /itouch/SurfaceTouchServicingKernelSKLMSHW0078.bin /itouch/vendor_kernel_skl.bin
sudo ln -sf /itouch/SurfaceTouchServicingSFTConfigMSHW0078.bin /itouch/integ_sft_cfg_skl.bin
sudo ln -sf /itouch/SurfaceTouchServicingDescriptorMSHW0078.bin /itouch/vendor_descriptor.bin
sudo ln -sf /itouch/iaPreciseTouchDescriptor.bin /itouch/integ_descriptor.bin
You'll then need to make sure you have the option to boot this kernel or set it to boot by default by configuring GRUB.
Zanna
  • 72,312
On SP4 touch algorithms runs on GPU so traditional drivers does not work
Here is the github link: https://github.com/ipts-linux-org/ipts-linux/wiki
Touch screen, Surface Pro pen..
IPTS stands for: Intel Precision Touch and Stylus.
In this github repo there is specific kernel with Touch screen driver.
Sorry for picking up a specific kernel but patches must be applicable to any kernel after 4.4.
ardaC
There is a Personal Package Archive (PPA) with the kernel packaged for you at: https://launchpad.net/~tigerite/+archive/ubuntu/kernel.
Follow the instructions "Adding this PPA to your system" and then do the apt commands specified.
It's probably better to start with an installation of Xenial (16.04) rather than Yakkety (16.10) since there has not been a recent (since May) update of the PPA.
Zanna
  • 72,312
I'm typing / mousing from Ubuntu 16.10 on SP4, To get here I did the following:
  • load Ubuntu using USB hub for keyboard/mouse support
  • sudo apt-get install the following two packages:
  • ukuu (EASY!) update to latest RC kernel (4.10-rc8). THIS now supports the magnetic SP4 keyboard/mouse (thanks, kernel people!). ONLY NIGGLE: wireless, so off to google and patch this.
  • grub-customizer to choose Win10/Ubuntu/Mint.
Ubuntu works with no horsing around, I chose 16.10 yakkety as I don't like 16.04 xenial min/max/close on UL of screen, and never found an easy way around this.
Linux MINT also boots with keyboard support (after upgrading kernel to 4.10-rc8) but not the mouse touchpad.
Zanna
  • 72,312
I've found the best kernel yet. It uses the same patch set that my other post describes, plus others that make the type cover work along with multi-touch on the track pad. I have it running with my 16.10 installation.
This kernel requires little work from the user since it is already compiled into .deb packages that you can download.
What works:
  • touch
  • pen
  • wifi
  • keyboard
  • trackpad
  • physical volume buttons and keyboard hotkeys
What doesn't:
  • sleep
  • occasionally buggy
There is no point in me plagiarizing the directions as they are dynamic and well put:
https://www.reddit.com/r/SurfaceLinux/comments/4t64zt/getting_the_sp4_running_with_ubuntu_1604/
